Why is my frigidaire washer not spinning? - Washing Machines
    President:
  • 693 Answers
  1. Stopped Mid-cycle
    • If your Frigidaire washing machine started spinning, but then stopped, verify that the power cord is still connected to the outlet. See if the outlet blew by plugging in a different appliance into the outlet. See if you blew a fuse. A blown fuse usually is either black or has broken wires. Replace the fuse. If you have a circuit breaker instead of a fuse box, reset the circuit breaker if it's been tripped. Check the lid switch, which is located inside the main housing of the washing machine, near the door frame. If the switch is burned out, order a new part from a Frigidaire parts dealer.
    Pump
    • The pump's sole responsibility is to remove water during the spin cycle. If the pump isn't working properly, see if it's clogged with debris or clothing. Use needle-nose pliers to remove these items. Check the pump pulley, which is connected to the pump. This component must move freely for the pump to work. If it won't turn, purchase a new pump pulley since you can't usually fix this component.
    Lid
    • Check the door latch assembly if the door isn't closing correctly. If any of these components are broken, order a new part from a Frigidaire parts dealer. If you do not, the washer won't start spinning since it believes the door isn't closed. Your Frigidaire washing machine won't start the spin cycle until the lid or door is closed. Always close the lid, and remove any items preventing the lid from fully closing. Always close the dispenser drawer.
    Additional Concerns
    • Never over- or under-load your washing machine. Your Frigidaire washer may not enter the spin cycle if the load is too large, since this can damage the washing machine. Remove a few pieces of clothing. If the load is too small, add a few similar items to the washing machine. Check the internal belt, drive motor and motor coupling. If any of these components are broken or very worn, they may not work properly, preventing the washer from entering the spin cycle. Order replacement parts from a parts dealer. Check the tub and basket bearings, and get new ones if the current ones have broken components or are defective.
Posted on Sep 27, 2011
Anonymous
SOURCE:
Frigidaire Gallery washer won't produce final high spin
Hey friend, thank you for your post!
I see that your Frigidaire washer, FWT449GFS2 is not entering the final high spin cycle. It is possible that you could have a defective motor or timer. Since it could be any one of these underlying issues I would recommend you having a professional come out to the home for the repair of your washer. -Matt
Aug 14, 2014 | Frigidaire Washing Machines
How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin Read more: How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin | eHow.com http://www.ehow.com/how_6496482
Hello - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly or the timer and control board not communicating correctly. Contact a professional to move forward accurately.
Oct 21, 2012 | Frigidaire Affinity ATF7000E Front Load...
My frigidaire washer FTF2140ES0 won't spin on the spin cycle
Hi there, the same thing is happening with our washer. Did you find a solution to the problem? We found a coin the the black tube, but it still doesn't do the final spin. I can hear the motor trying to do something, but it just won't do the final spin. If anyone has any idea or suggestions it would be greatly appreciated. In the meantime, I have a load of slopping wet laundry to deal with. :(
Jan 04, 2010 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
I have a frigidaire washer, when drum spins it
It is probably the belt.. Replace the belt and that should take care of it..
Have a nice day..
Sep 08, 2009 | Frigidaire CWS3600AS Top Load Washer
Washer won't spin in final spin out
Hello harley1964dm
Welcome
You said, you have a Frigidaire front loader and it will not spin out in the final spin would you please help me. thanks
For a Frigidaire usually ,
If the washer won't spin.
Many times it's because the load is too small. Add 1 or 2 similar items to help balance the load.
If it does not remedy the problem try unplugging the machine for 5 minutes which will reset the system!
Let me now how it goes.
Huuum
Please remember to leave a rating
Oct 11, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
553 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
