I have the same problem my mower will start fine and then shut off i cleaned the carbureter and it still does it. I can keep it running with carb cleaner but it wont run on it's own. what should i do?
I had same problem and removed the float bowl and blew thru the tiny hole in the screw that holds the bowl on and it now runs fine.I had same problem and removed the float bowl and blew thru the tiny hole in the screw that holds the bowl on and it now runs fine.
You can't post conmments that contain an email address.
Sounds like your seat switch isn't working. Operator presence (seat switch activated) is required when the brake is released & pro is engaged or your engine will shut down.
Sounds like you have a hole 'burnt' in the piston top allowing fuel combustion mixture (normally compressed above the piston) getting down into the crankase or that the piston rings are shot allowing the same thing.
As the piston is continuously moving, the reverse happens giving oil at the intake or carb.
. Looks like a strip down, good inspection and rebuild of engine required .
