Averatec 3200 Notebook Logo
Posted on Sep 17, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fan/Overheating issues averatec 3200 series Laptop
Does anyone out there have averatec experience? I have a 3200 series laptop I bought refurbished. Here's the tricky part. Where your right hand would go as you type, the sticker says 3200. On the back of the computer a sticker says 3250.
The fan started off quiet. 2 years later it gets loud, then noise lowers, gets loud etc then seems to over heat at shuts itself down.
So I assumed it was the fan that needed replacing. I found one online, replaced it,
Now its the same thing, fan noise high, fluctuates, sounds low, but only shuts itself off on occasion now. After I had replaced the fan a friend told me it sounds like the fan isn't getting the appropriate voltage which would make the fan noise fluctuate like that. He said it had something to do with BIOS which I know nothing about. But , when I checked into it, its password protected someone please help!! Thanks!
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jun 14, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
20043
Points
7
I had the same problem and went into the CMOS, Power Management and ran the FAN Learning feature. It runs for about 10 minutes and then chooses the right fan speed for your machine. My machine's fan was running really high. After this test, it ran a lot slower and did not overheat anymore. I also use a fan underneath the machine that plugs into a USB port for extra air control. No more issues.
Anonymous
Level 2:
  • Expert 93 Answers
  • Posted on Sep 18, 2008
Anonymous
Expert
Level 2:
Answers
93
Questions
0
Helped
70285
Points
223
Fans on laptops run when the CPU is taxed. The more its taxed the louder it will be due to higher fan speed. The laptop over the years has gotten bloated with programs and stuff that gets in and stays on your hard drive. The more programs running in the backround the more the CPU is taxed. Try uninstalling useless programs first, empty your recycle bin, delete temporary internet files and cookies, run the disk cleanup utility then perform a scan disk and a deframent. Also you may want to add more memory to your system if it needs it. I use crucial's website (crucial.com) to scan the computer and tell me what memory I can use in my machine. Hope this info helps you out.
A
Anonymous
That happened to me as well. I thought it was the fan or the BIOS. It turned out to be the battery.
Test my solution on your computer. Take the battery out and use only the power supply. If it works the laptop will not turn off.
The battery seems to give off a funky discharge making the board and fan act funny.
I hope this helps.
  • Anonymous Nov 13, 2010
    your solution for power management is great but i would not recommend using the USB port of any laptop to charge up external devices (such as fans) unless when really necessary, such as when an external data back up HD unit with no PSU is the device that has to be attached and requires to drain power off the laptop rather than an external PSU.
    i managed (successfully!) to have one of the two memory slots on my laptop (a Dell Inspiron 600m) burnt down (plus its PSU was sadly damaged too) via attaching small keyboard lights and battery chargers etc to the USB port of the poor laptop, which was otherwise working really fine.
    i had only just upgraded the machine's memory from 256MB to 1GB (2x512MB memboards) and it was really good and fast but now i have only 512 attached to the remaining memory slot. and the repair costs, if workable at all that is, are not worth it really. i was hoping to max out the memory to 2GB btw, but sounds like it's not possible to do so anymore.
2answers
Need to put a fan in my 3280 seires averatec is ther a parts list of the inside of the computer would like to fix myself
http://www.insidemylaptop.com/take-apart-averatec-3200-laptop/
This might help you with dismantling it
Lost Installing CD cant install to windows XP my computer is averatec 3200 series
here they are , I could not find free cd:
Averatec 3200 XP Windows Driver Recovery CD Restore DiskThis is an automated 3200 XP drivers recovery cd. The 3200 drivers are supplied in a special windows friendly format. This means that your Averatec 3200 XP Laptop will automatically find and install all the drivers for your system, with hardly any user interaction. If you have installed a new windows operating system and half of your Laptop just wont work (with errors like no sound no internet or bad graphics) then this is exactly what this CD has been designed to fix repair. You can also use this CD Disk If you just need to return you.....lots more averatec 3200-series drivers information here.
http://www.user-guides.co.uk/Averatec/AveratecDrivers/Averatec.asp?keywords=Averatec+3200-Series+Drivers&recor=1
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
My Averatec 3200 keeps shutting itself down. The
A common problem with all laptop is dust. Sounds like you have 5 years worth of dust stuck in there. You should get a can of compressed air and blow though every vent you can! You want to loosen the dust that's in there and possibly try to blow it out and/or get it closest to the vents.
After that you should take a vaacum cleaner and **** out all the dust you can!
Dust inhibits air flow, alot! Its the number 1 killer of old computers.
1helpful
Suddenly getting boot failure message averatec 3200
this could be do to a bad connection to the boot device such as the harddrive.
I would try to boot from the cd rom using the OS disk.
I have an averatec 3200 laptop.no display
Yes..most probably its HDD. Remove the hrddisk and try booting. If it displays, no HDD.then the prob lies with HDD.
2answers
Drives needed
ajib dasta hai ye
Averatec 3200 Series Laptop
If you have access to another machine you can create a disk to fix the ntldr issue. Please see the following website. http://www.tinyempire.com/notes/ntldrismissing.htm
1helpful
Averatec driver
There support site can be found here
Averatec 3200 Laptop
your laptop cooling fan want replacement
CPU Fan Error - Averatec 3200
First, download PC Wizard 2008 so you can check the fan speeds and temp of your CPU (and every other component of your PC if need be) and see if it's operating properly. You can find it here:
http://pc-wizard-2008.en.softonic.com/
If it's malfunctioning, you'll need to replace it.
Top Averatec Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
