Canon CanoScan 4400F Flatbed Scanner Logo
Posted on Aug 12, 2017
Hello, My Canonscan 4400f driver does not work when I want to scan. I have a MAC OS X 10.6.8 It worked for years. But I emptied my computer and downloaded several times from the internet. But it keeps saying "failed to open a driver" when I push the SCAN button. I hope this is just a common problem. And I hope sincerely that you can help me. Regards, Esther from Amsterdam
Akri Mande
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 07, 2019
Akri Mande
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
451
Points
I foun d this ..
https://canon-driver.org/canoscan-4400f-driver/
I hope that will helped
4 Related Answers
Anonymous
  • 30 Answers
  • Posted on Nov 23, 2008
SOURCE: Canon N650U and Mac OSX
Canon only has this scanner driver in OS9 and it will run in classic mode if you are using OSX. This $40 software will work with your scanner in OSX, but for $40 you can purchase an OSX native scanner too.
http://www.hamrick.com/index.html
Anonymous
  • Posted on Mar 12, 2009
SOURCE: failed to open a driver
OK. Here is what you do. (I just did this on an Intel Mac running OX10.5.6)
First go to the cannon site and get the program (File name: deldrvosx1510en.dmg) to uninstall the drivers for your scanner. Also, delete copies of the scan toolbox that you may have installed in your application folder.
Then go back to the canon site for the LiDE 25 and install the drivers (file name: lide25osx11030en.dmg.) This part is very important, in the middle of the install a dialog will popup asking if it is OK to run something like deldvr, DO NOT ALLOW IT TO RUN, HIT CANCEL.
reboot.
Install the canon toolbox software (it should be version 4.9.x not 5.0). File name is : cstbosx4934ej4.dmg
You should now be good to go.
What a %^#%$#-up process on Canons part.
Anonymous
  • 120 Answers
  • Posted on Dec 27, 2009
SOURCE: Every once in a while (after 10 or so scans) the
unplug the connections and power supply for a minute or so and plug back in. Make sure you have the latest driver as well.
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Mar 19, 2010
SOURCE: Looking to download a driver for CanonScan Lide 20 for Mac OSX
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=6624
OS 9 ??? Thats the ONLY one.
How do i set up scan
You need to install canonscan toolbox software, the interface is user friendly and scanning is just one click from there. but before installing that make sure install mp drivers first.
mp drivers - select your os and look for it
canonscan toolbox
RE Canon scanner problem 'No driver found'. downloaded new updated software twice and got the same message. Using Apple Mac Os x (snow L.)
Pls disconnect the scanner, uninstall scanner driver and switch of the computer. After restarting, run Scan disk and then install appropriate driver for MAC OS and connect the scanner. This should work.
S. Mohan
1helpful
Push button to operate and nothing happens
Scan via Twain plugin (photoshop) for the N 650U is the only solution working for me. Front button stopped working after a needed update 3 or so years ago, don't expect that to work anymore.
I am using Mac OS X Snow Leopard on an Intel MPB.
- - cognitdiss
3helpful
I need driver for my Canonscan 4400F
Download it from Canon, just select your OS:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=13810
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Canon N122OU driver for Mac OS X Leopard
Please find here the direct link to your scanners driver and manuals:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=8007
I am unhappy with the light level while scanning slides.
I haven't solved the light problem, but I have found a pretty good program that allows me to enhance my scanned slides-pics into nearly slide-projector quality pics: XnView. I have found that it is best to not try to use the enhance program in PhotoStudio 5.5 (the driver-program for the Canonscan 4400F).
1helpful
Reinstallation
Always get the original manufacturer's drivers directly from their website. Be sure to select the correct Operating System (like XP or Vista or Mac OS).
Canon CanoScan 4400F Drivers
Thanks for rating this Solution!
old marine
old marine
ZJ Limited
ZJ Limited
