Watch backs come off several ways, the most obvious would be screws you would see the screws be very careful not to strip them, the next way is screw off backs there would be even indentations all the way around back where the tool inserts to unscrew the back, if it is screw off you need to go to your local jeweler. The third way is just pop off, you need to make sure edges of watch around back lid are clean (you can do this with a tooth brush) and then look for a lifting spot a small indentation sometimes very hard to find! Use the blade of a pocket knife to gently pry it up it will make a popping sound when it comes off. good luck i hope this helps !!
