I found a part with the following code on it: 5600 037 096 and PP-TV20 inside my dishwasher. I don't know where to put it. Can you help me?
I have a Bosch dishwasher with the same "mystery" part. According to my manual,this part is an Extra Tall Item Sprinkler (select models). Apparently, if you are loading in extra tall items, you take out the top rack and insert this part into the top rack spray outlet (located a the back of the dishwasher). Turn it clockwise to lock it into position. Put your extra tall items in the bottom rack. Hope this helps!
It a "Baking Sheet spray Head, Take the top shelf out of the dishwasher and fix it on the back of the inside of the washer, on the circular male fitting, between the two protruding bits and rotate to secure.
For cleaning large Pasta plates etc
Per page 27 of Bosch 9000 530 626 (9002) manual
It goes in place of the upper dish rack arm. the arm is removed and this part is attached to the water inlet at the back.
Can someone suggest a reason to use it?
We found that part inside ours. it twist snaps on to the water out let at the back of the unit where the top sprayer arm normally connects. although we cannot find a reference in the manual, it looks like it is for cases where you want to remove the top rack to wash a tall item.
The reference refers to the actual material the parts are made from, not the part number.
It is a talc filled (20%) co-polymer polypropylene produced for injection moulder by pal plast GmbH in Germany.
I just found the same part in a "junk" drawer. Seems pretty useless unless you are washing the kitchen sink. Mine is a Bosch part---they should stick to making stereos!
Hi all. I just found the same part. It appears to fit to the inside roof of my Beko dishwasher - not at the back as others are suggesting. See photo.
me too. what's it for?
Same problem!
It happened to me too, did you yet found out where it goes?
We also have that problem and can't get an answer from anybody.
It also came out of an AEG dishwasher
I have the same part (5600 037 096 >PP TV20<
Any advice as to what it is for would be appreciated.
Bill
[email protected]
Pull top drawer out and install pp tv 20 in back where top shelf meets the back and wash extra tall/ big dishes without top shelf installed.
