Step Action
1 Power off the printer and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the printer on.
Did the error message return?
Yes: Continue to step 2.
No: Attempt a test scan. If the error message does not reappear, the error is resolved.
2 Power off the printer and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the printer. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the printer on.
Yes: Continue to Contacting Lexmark.
No: Continue to step 3.
3 Power off the printer and remove the power supply from the back of the unit. Open the top cover of the printer. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the printer.
Yes: Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No: Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
4 Power off the printer and remove the power supply from the back of the unit. Open the top cover of the printer. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the printer on.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved.
