Yamaha SPX2000 Digital Effects Processor Logo
Posted on Sep 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello, Im singing in a piano bar in Hong Kong. We cannot do a sound check and try the best effect for voice. The equipment has a Yamaha spx2000 effects processor. Please, can you tell me what is the best Effect for female voice? It's a not so big place.My band is acoustic piano, drums and electric bass. Ill appreciate your help. Thank you so much! Kelly
Geoffrey
Level 2:
New Friend:
  • Expert 65 Answers
  • Posted on Sep 16, 2011
Geoffrey
Expert
Level 2:
New Friend:
Answers
65
Questions
0
Helped
15008
Points
146
One of the 'plate' type reverbs is usually best on vocals. Preset 16, 19 or 26 should be suitable.
Testimonial: "Thank You! I'll try this."
2answers
How can I Import and export voices from or to Yamaha DGX 640 from my PC running with Windows 10 ?
ask yamaha this, direct to them or read the manual firsts. 2010 made.
lost the manual ? did you?????
any app you run most be from maker yamaha for w10.
Yamaha DGX-640 88-Key Portable Digital Grand Piano with Weight-Graded Hammer Action.all there is , is here
yam
https://usa.yamaha.com/support/updates/index.html?c=digital_pianos&k=640
https://usa.yamaha.com/files/download/other_assets/2/314552/dgx640_en_om_a0.pdf
i guess you talking about what page 15 states.
then page 97 how to do it>?
what it can do is all there song file wise.
it shows w7 max.
but some apps w7 sure can be loaded to w10 or drivers
using windows 10
w7 compatibility mode as MS tells you.
seen here.
windows 10 32bit or 64 I see this too
https://usa.yamaha.com/support/updates/index.html?c=digital_pianos&k=DGX
try these?
2answers
Can a Yamaha PSR 500 be used as a standalone piano?
Yes you may use it as stand alone piano. Usually everytime you will power ON any yamaha psr model piano will appear as default voice.
I have a Yamaha MM6 - only the piano category works - the wheel jogs through the voices. No other category works and no functions work. No lights are on apart from the display.
maybe this will help ...... I have a Korg M1 ..... it has a small button battery for maintaining memory and sounds .... mine lasted about 10 years ...... I looked up in Google how to change the battery .... I looked up in my M1 instructions how to reload the sounds .... I had lost all my synth sounds except the basic piano ...... I changed the battery and reloaded the sounds from a backup card I had bought years ago .... M1 works perfectly now .... you probably lost any saved songs .... contact Yamaha how to change the battery and reload the original songs .... any saved songs are gone .... next time, back them up ... good luck
Anyone knows what could happen or if there is a chance to be repaired?
Hello, Magda -
Only an authorized Yamaha digital piano (Clarinova) service technician can answer your question regarding a chance of repairing your piano.
If you have not already done so, you can locate an authorized service technician here:
https://www.yamaha.com/paragon/servicerlocator/
Best wishes.
My yamaha psr s 700 changes sound sometimes hand with all d bottons Woking if I start d keyboard all botton will not come up util 20mins after switched off plz I really a solution cus im so tired
lots of issues there
will need taking apart to find the faults and repair
some possibles
power source input low
internal circuity faults
switches
dry solder
diode faults
internal dust build up
One of Yamaha's new arranger keyboards, the PSR-S700 is the more entry-level model, but still comes with a range of impressive features:
  • 61 touch responsive keys
  • 96 notes of polyphony
  • 5.7-inch QVGA LCD capable of lyrics and score display
  • AWM (Advanced Wave Memory) sample sounds
  • 813 preset voices made up from 317 voices, 16 drum kits, 480 XG voices
  • 10 MegaVoices
  • 11 Sweet! Voices
  • 18 Cool! Voices
  • 14 Live! Voices
  • 9 Organ Flutes
  • 2 layer voices
  • Large number of preset and user-definable effects including reverb, chorus, 4 x DSP (Digital Signal Processing)
  • 205 preset 8-part auto-accompaniment + user category with mixer controls
  • 16 track recording
  • 30,000 note capacity
  • Performance assistance technology
2answers
Hi, when I play a chord on my Casio-656 keyboard it sometimes sounds out of tune - if you hit the chord again it plays correctly. Is this a fault or a setting? It seems to be intermittent so that would...
I would check your fingering... You MAY be late in hitting a particular note and the using auto chord... this can cause the problem. Another thing is if notes are hit with different velocity that can affect the sound. Sometimes certain voices have VELOCITY switching which actually changes the voice depending on the velocity you hit a note.
May 19, 2011 • Casio Music
1helpful
There is a tinny unpleasant sustain in the high notes with or without pedal. Is there an adjustment to mellow this sort of ringing (the keyboard is set all the way to "mellow") we tried...
Some of the Yamaha pianos have several pianos emulated and selecting a "Grand" will sound different than if you select an "Electric" or "***** Tonk" setting.
There is NO internal adjustment for this. other than the voice selection. Choose either the Grand1 or Grand2. Do not use reverb as this can "ring".
Top Yamaha Music Experts
Paul Bade
Are you a Yamaha Music Expert? Answer questions, earn points and help others
