Master
- Posted on Sep 15, 2011
Re: How do i change the filter in the amana my ice taste...
Water filter is located in the upper right hand corner of the fresh food side.
Follow these steps:
- These eight inch long filters are housed in their own compartment.
The base of the compartment can be released by pushing in on the release
clip found at the end of the housing unit. Allow the base of the
housing compartment to hang down while you remove and replace your
filter.
- Twist the spent filter to the left (counter-clockwise) and gently
pull on it to remove it. There is an automatic water shut off to keep
leaks and spills to a minimum.
- Remove the new filter from its packaging. Remove the plastic wrap,
and peel off the aluminum topping. Insert the new filter into the
housing unit. Twist the filter to the right (clockwise) until it clicks
into place. Replace the base of the filter housing by cliping it back in
place.
- Condition the filter by dispensing several glasses of water through
your refrigerator. This ensures that all fine carbon particles have been
removed.
- Check the filter and the inside of the refrigerator for leaks. If you find a leak, remove and install the filter again.
