Frigidaire ATF6000ES Front Load Washer Logo
Posted on Sep 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The locking mechinism does not engage. The light does not come on for the lock light to start.
onthethejob1
Level 3:
  • Master 640 Answers
  • Posted on Sep 11, 2011
onthethejob1
Master
Level 3:
Answers
640
Questions
Helped
208721
Points
1483
the locking mechinism does not - onthejob5130_3.jpgonthejob5130_4.jpgCheck your door probe ,,thats the picture on left are prongs still there ,,if not replace,,,the picture on left is door switch which the probe goes in when you close door,,its a chance you may have a bad door switch..good luck
I have a Whirlpool Duet washer. The add garment light is on. The door does not lock when press start. doesn't matter what cycle I try,washer will not start only beep and flash lights.Tried unplugging
If the door lock is not engaging the control will not allow a cycle to start as a safety precaution, so the door lock assembly will need to be replaced if the door will not lock. You can order the new door lock assembly from the link below Genuine 8182634 Whirlpool Washer Door Switch Assembly eBay
Kenmore front loader washing machine won't start
You will need to replace the door lock. Here is the part to order.
To replace the lock, remove the band securing the boot to the front panel and fold back the door boot. Now you can access and replace the lock. Let me know if you should need further help.
2answers
My steering wheel is locked, and i just cant unlock it. everything is jamed
use some elbow grease to pull and push the wheel whilst operating the key
I have a problem closing my boot lock on my Audi A4 year 2003. It does not appear to engage the the reciever on the body of the car
try to spay some WD40 on the mechinism and see if it helps ... if it works and the boot remains closed then open it and lubricate it with some lithium grease (comes in a spray can.) Do the bonnet latch as well while you are at it.
3answers
Cannot open rear hatch. have all internal panels off and can manipulate cable attachment to the locking mechinism but door still does not release. Im thinking that I will have to cut out lock mechnism just...
You can pry open the latch with a screw driver or lastly grind the latch. Try grabbing rod or cable with locking pliers and try pulling while prying at the same time.
1helpful
Dacor CPO230, can't get lock to engage for self cleaning. I follow step clean symbolcomes up door lock moves into locked position then beeping starts and the word door flashes and the lock opens up.
For some reason the oven thinks you have a door that is not shut all of the way. Check the locking slot to make sure that there are no obstructions. Make sure that you are only doing one oven at a time, and not trying to cook in the other. Make sure you have no racks in the oven. Try pushing lightly on the door when the lock engages. For some reason your lock isn't engaging fully and that's why door is flashing. Good Luck
Below is from the owners manual for your oven.
Oven does not self-clean Door not shut tight Check for obstructions. Close door tightly
Oven set for delay timed cleaning Oven will start to self-clean at preset time.
Press CANCEL/SECURE to return to
normal operation
Double ovens only: Other oven is on. Turn off other oven.
2helpful
A4 steering lock does not engage and car won't turn over
The steering locks don't necessarily engage when the key is removed, I always turn the wheel before exiting to engage it. There are several positions that will allow the pin to lock in but if between these, it may seem that it isn't locked.
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
