Hello
& Welcome to FixYa You
will have to take it apart completely, this repair manual will help you in doing
so. Please get back to me if you have any other questions. Kevin
This is the repair manual for your Maytag MAH8700 model.
Service/Repair Manual is a Techs/Training Manual only for professionals/experts, it is not the usual Owners/User manual supplied with the washer. The manual that I have given you tells you how to remove the panel to remove those coins from the tub or the drain pump. Moreover, it is always better to open the manual rather then just simply pointing fingers at someone. No offence though but I am here to help you and can even help you for free. Thanks again.
You too.
Great its solved! Happy for you :))
I have the MAH8700AWW. It was purchased in 2006. The manual that was sent doea not have details on how to tear it apart.
I have already looked at the service manual that came with the machine. There is nothing in there to tell me where the coins would get stuck nor any diagrams about how to disassemble. I guess that I was expecting an answer such as: Take the nut off of the drum, then take the 5 screws that take the cariage off and you will see the coins. For $15.00 I would expect that. Not refer to your service manual that is clearly written for a maytag specialist. Sorry, but I am not satisfied. Your reply should be "Fixing a Washing Machine for dummies 101"
Sorry!! This should help. Have a nice night!
All fixed up!! Sorry for assuming.......You saved me a bunch of $$.
I received the solution to the repair in less than 5 minutes. Took me less than 5 minutes to fix. The last time this happened it costed me $200.00. Thanks again Kevin!!!!!!!!!!!!!!
Kevin sent the solution to repair my washer in less than 5 minutes of my request. I was able to fix it "myself" (WOW) in less than 5 minutes. My wife asked me if my dad stopped over.The last time this happened I was charged $200.00++ from a local repair company. Will definitely use this site again as well as any advise that Kevin gives. THANK YOU!!!!!!!!
