SOURCE: jvc hdmi????
Changing the output to digital only affectts the audio output stream such as Dolby Digital or DTS audio. Try turning on the DVD player first then the television and see if then it sees the DVD player. Otherwise using the component outputs most will never see the difference n picture quality. Good luck.
SOURCE: HDMI input failure
Hey guys, had the same problem. Found this solution on the web. Worked for me.
JVC HDMI Port Fix
Turn the TV on, and enter the Service Menu. Select 2 for Self Check. Then turn the TV off, and after the fan turns off, unplug the power cord. Reconnect the power cord, turn the TV on, and the HDMI port is reenabled.
Here’s how to get to Service Menu:
Before entering the SERVICE MENU, confirm that the setting
of TV/CATV SW of the REMOTE CONTROL UNIT is at the
"TV" side and the setting of VCR/DVD SW of the REMOTE
CONTROL UNIT is at the "VCR" side. If the switches have not
been properly set, you cannot enter the SERVICE MENU.
1) Press [SLEEP TIMER] key and while the indication of
SLEEP TIMER 0 MIN is being displayed, press
[DISPLAY] key and [VIDEO STATUS] key (Fig.2)
simultaneously.
2) The SERVICE MENU screen of Fig.1 is displayed.
3) Verify what to set in the SERVICE MENU, and set
whatever is necessary (Fig.1).
Refer to the SERVICE ADJUSTMENT for setting.
4) Press the [BACK] key to return the SERVICE MENU.
This should work.
JVC AV-48P575 HDMI reset procedure:
1. Unplug HDMI cable from tv.
2. Unplug the tv.
3. Remove the rear (low) back cover.
4. Find the 6 pins on the board of the HDMI module and shortcut the pins no.1 and no.2 using a jumper(i use an old hard drive jumper).That's the higher to pins if you can't see the number.
5. Put back the rear cover.
6. Plug the tv.
7. Turn on the tv.
8. Unplug the tv(without tunrning it off).
9. Remove the back cover.
10. Remove the jumper on the pins 1 and 2.
11. Put back the rear cover.
12. Plug the tv and you're done.
