Question about LG WM-2277HW Front Load Washer
Suggest try same again.
Modern appliances have a zillion circuit connections of which any one of them can develop a "bug".
Unless it is under warranty it's usually less trouble and cost to simply replace it.
Posted on Jan 02, 2018
SOURCE: LE Error Code on Tromm
http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf page 18 of this service manual elaborates on the LE error code and what to check.. Hope this helps you..
Regards
Posted on Sep 20, 2008
SOURCE: I HAVE A LG TROMM WM2277HB and its not spining
First try unplugging the machine for a few minutes and then retry a cycle. If you still get the LE error:
The Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in the US). Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000
Posted on Jun 12, 2009
SOURCE: Error Message and Tub not spinning
Depending on how many clothes are in the washer you may a unbalance error
Posted on Jul 31, 2009
SOURCE: My washer is marking LE.What does that mean?
This is a motor overload. Could be too many items in the barrel. I have had this code in the past and took some items out and it went away. I still think there is an underlying issue with the hall sensor or the motor altogether.
Posted on Aug 01, 2009
SOURCE: my dispenser is jammed Lg Tromm wm2277hb
you will have to raise the top if its top loading and disconnect the hose connected to it,if its the detergent dispenser and if it's the fabric softener one with the bleach dispenser with it there will be two hose connected to it and possibly some clips holding it in not sure all machines are different.
Posted on Aug 24, 2009
Nov 24, 2013 | LG WM-2277HW Front Load Washer
Mar 22, 2017 | LG Tromm Front Load Washer And Dryer Set
Jan 21, 2013 | LG 4775er2002a Door Hinges for Wm2277hb...
Mar 02, 2017 | LG 4775er2002a Door Hinges for Wm2277hb...
Sep 27, 2011 | LG Washing Machines
Jun 19, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Jun 08, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
May 16, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Apr 18, 2010 | LG WM-2277HW Front Load Washer
Jul 21, 2009 | LG WM-2277HW Front Load Washer
144 people viewed this question
