The plastic coupling on the sink sprayer attachment has broken in half. Is there a way to replace it without disconnecting the sprayer hose? We have the spray attachment off but the end left on the hose is too big to slide off.
First clean out your cabinets under the sink. Second turn turn the cold water valve off, hot water valve as well. You should be able to locate the sprayer hose as it will have a weight on it, this helps to pull the sprayer back when you are finished with it. Remove the weight by lifting up on the tab should be on the center of the weight. Then you should see the hose connection.There you should see a button.Push it in and give it a little tug. The hose should be disconnected. Just follow in reverse order to reinstall. I hope this is information is helpful. Have a blessed day.
Turn off the water supply valves beneath the kitchen sink. Turn on the faucet and squeeze the trigger on the sprayer to empty any water left in the supply lines, faucet and sprayer.
Trace the sprayer hose from the end of the sprayer to where it connects to the faucet. Use pliers to loosen the connector holding the sprayer hose to the faucet.
Remove the sprayer hose from the faucet to expose the male threads. Wipe the threads dry with a towel. Wrap the threads with pipe-joint tape. Twist a 3/8-inch threaded brass flair cap onto the male threads. Use the pliers to tighten the cap.
Reach beneath the sink and loosen the mounting nut securing the sprayer support to the sink or countertop. Use a basin wrench if you are unable to reach the mounting nut with your hand.
Slide the mounting nut off the hose attached to the sprayer beneath the sink. Pull the sprayer support and the sprayer from the hole in the sink or countertop.
Insert a sink hole cover into the hole left by the sprayer. Depending on the style of hole cover, it could snap in, or a mounting nut could hold it in place.
The sprayer itself may be attached to the underside of the wiper arm and is removable. Carefully remove the sprayer, disconnect the hose, and turn on the wiper and the washer. It liquid comes out of the hose, the sprayer is clogged. If no liquid comes out, the hose could be clogged, so replace the hose. You need to find the other end at the black plastic manifold that divides the washer flow into the two sprayers. Disconnect the passenger side and blow into in, just in case to unclog it, then try again. If the washer is working for the driver side, that manifold is unclogged.
Soaking the sprayer overnight in vinegar could unclog it., but the sprayer is cheap to buy new.
I've had problems with the O-rings at the head leaking, feeding back inside the corrugated hose covering, and pooling under the sink. Might be your problem as well. Verify by holding the head downward, and look for water beading out further up the hose.
Most new kitchen faucets feature single-handle control levers and washerless designs that rarely require maintenance. Additional features include brushed metallic finishes, detachable spray nozzles, or even push-button controls.Connect the faucet to hot and cold water lines with easy-to-install flexible supply tubes made-from vinyl or braided steel. If your faucet has a separate sprayer, install the sprayer first. Pull the sprayer hose through the sink opening and attach to the faucet body before installing the faucet.
Where local codes allow, use plastic tubes for drain hookups. A wide selection of extensions and angle fittings lets you easily plumb any sink configuration. Manufacturers offer kits that contain all the fittings needed for attaching a food disposer or dishwasher to the sink drain system.
I had the same issue with an American Standard faucet that I installed new 6 months ago. The diverter can be the issue if you have a sprayer attachment. Try unscrewing the sprayer head from the hose it's attached to. Now run the water full pressure with the hose pointed into the sink, obviously :~). After running the water for about 1 minute, connect the sprayer head back onto the hose, make certain the flat rubber washer and ring gaskets are seated in their grooves properly, and tighten until you have no water leaking from the sprayer head/hose connection. Now try the water through the faucet. If the problem was a temporary diverter issue, your pressure should be fine now. Good luck
The hose that goes to the Sprayer has to be disconnected under the sink at the main connection there, then it can be pulled up and out of the top of sink. the you can unscrew the nut under the sink on the flange and remove and replace.
It may also be a missing weight on the sprayer hose, or that the sprayer hose is obstructed. Open up the cabinet under the sink and look a half-loop of the sprayer hose that should be hanging down from the underside of the faucet. It must be able to descend without obstruction as you return the sprayer to the body of the faucet. If it is resting on a box of dishwashing soap or otherwise obstructed, then it doesn't have it's full weight to counterbalance the weight of the sprayer head. Capice? It needs the weight of the hose to 'weight it down'. Also, there should be a donut-shaped weight around the hose that should be able to freely slide to tha lowest position of the half-loop as the sprayer is extended and returned. Make sure that's working too.
Many new faucets require some assembly before mounting to the sink; if that is the case, follow the manufacturer's directions. With most pullout sprayer faucets, the sprayer needs to be threaded through the faucet body first. Insert the rubber gasket between the base plate of the faucet and the sink top to create a watertight seal. If no gasket is provided, pack the cavity of the faucet with plumber's putty, then insert the faucet body through the holes in the sink top. Thread the mounting nuts provided onto the faucet shafts, then center the threaded shafts in the sink's holes and tighten the nuts firmly. Many manufacturers include a special long socket specifically to aid in tightening the mounting nuts. A hole in the socket accepts the shank of a screwdriver, guiding it as you tighten the nuts. If you're mounting the faucet on an installed sink, use this method. If you're installing a pullout sprayer faucet--or a faucet with a separate sprayer--now is the time to connect the sprayer to the faucet body. Check the manufacturer's directions to see if using pipe-wrap tape for this connection is recommended. Use an adjustable wrench to tighten the connection. Most pullout sprayer faucets and faucets with separate sprayers come with a counterweight that attaches to the sprayer hose. This weight helps retract the hose back in to the sink cabinet after you've used the sprayer. Follow the manufacturer's directions on where to secure the weight, and take care not to crimp the hose as you attach the weight. Hook up the faucet's hot and cold supply lines to the water supply shutoff valves under the sink. If necessary, gently bend the copper tubes coming out of the faucet for better access and connect flexible supply tubes to them. Simply wrap a couple of turns of pipe-wrap tape around the threaded nipples on the valves and connect the tubes. Tighten the nuts with an adjustable wrench.
