Cars & Trucks Logo
Anonymous Posted on Sep 08, 2011
1997 chevy malibu anti theft system how do I fix this problem The car won't start I believe the car is in the anti theft mode
Anonymous
Level 2:
Sniper:
  • Expert 96 Answers
  • Posted on Sep 10, 2011
Anonymous
Expert
Level 2:
Sniper:
Answers
96
Questions
0
Helped
44231
Points
354
The late-90's GM Passlock system (e.g. 1997 Malibu, Regal, Impala, etc.) has a part around the ignition tumbler that goes bad and no longer reliably detects the valid key. In that situation, the "Theft System" light will slowly flash and the carburetor is cut off so the engine won't start. The time-out on the system is 10 minutes - you don't have to do anything, you don't have to disconnect the battery, the key can be out of the ignition -- it's just a time delay. After 10 minutes, the light goes out and you can try again (but if the key is again not detected, the light will start flashing again and you have to wait another 10 minutes)
Someone else, who had this problem, told me to remove all other keys from my keyring. The weight of the other keys pulls on the ignition key causing the key to be unreadable. It has been 7 weeks since I have been doing this and have not had a problem
How do I start 1997 chevy express 3500 with the wires?
You can't. It has an anti-theft device. The days of boosting a car with a couple of wires ended in the 1980s! You have to fix the problem, not find a way around it.
General Motors Vehicles Equipped with PASSLock ...
www.locksmithledger.com > keys-tools > article > gene...
The PassLock system was designed to prevent vehicle theft by disabling fuel to the engine if ... Chevrolet Silverado 1997-2004. Chevrolet Sport Van 1997-2000
CHEVY EXPRESS GMC SAVANNA VAN 2500 3500 ANTI ...
www.ebay.ca > ... > Other
REBUILT WITH LIFETIME WARRANTY GM Passlock Anti-Theft VATS module. PART NUMBER 16264985. THIS PART IS OBSOLETE AND UNAVAILABLE AT ... Rating: 5 · ‎2 reviews · ‎US$149.99 · ‎In stock
16264975 GM Passlock Chevy Express GMC ... - Amazon.com
www.amazon.com > 16264975-Passlock-Express-Anti-...
Buy 16264975 GM Passlock Chevy Express GMC Savanna Van C3500 Anti-Theft Vats Security Module REBUILT: Anti-Theft - Amazon.com ? FREE DELIVERY ...
What does a car with a lock light mean
Chevrolet Malibu Questions - SECURITY SYSTEM LIGHT ...
www.cargurus.com > Questions > Chevrolet > Malibu
CarGurusFeb 3, 2014 - SECURITY SYSTEM LIGHT COMES ON - CAR TURNS OVER WON[T START ... Insert the ignition key into the driver door lock. ... When I start my car 3 keys programmed pops up on my dashboard what does that mean.
Chevrolet Malibu Questions - Why does the anti theft system ...
CarGurusFeb 23, 2011 - Why does the anti theft system keep tripping on my 03 malibu - Every other day my anti-theft system goes off in my car then I have to reset it. It's not ha... ...it needs a pass lock sensor/ ignition lock cylinder. 10 out of 10 people think ... Wait 10 minutes until the light stops flashing, then start. Repairs could run ...
No Start Due to Failed Passlock Sensor : Chevrolet Malibu ...
repairpal.com > Problems > Chevrolet > Malibu
Reset anti theft system 2007 Chevy Malibu
Here are two methods to reset the anti-theft system on 2007 Chevy Malibu:
1st method
1. Put the ignition in on position, let it breathe for 10 minutes, and remove it when the anti-theft system light stops blinking.
2. Crank up the engine; it should now start
2nd method
• While outside the car, press and hold the lock and unlock button together
• Let go when the car honks and the lights flash
• Put the key in the ignition and rotate to the ON position, and leave there for 30 seconds
• Switch on the car, and the anti-theft system would have reset
2002 chevy malibu...can i get a remote starter to by pass the anti theft system
What makes you think this is a anti-theft system problem ? Is the security light lit on the insturment cluster ? When you turn the key to start does the starter spin the engine ? Crank no start ! Or when you turn the key to the start position the starter does nothing . No crank no start . A aftermarket remote start won't by pass anti-theft system . Your best bet would be to take to a qualified repair shop and have it checked for DTC'S - diagnostic trouble codes . Before you let someone start hacking up wiring circuits .
DTC B2947
DTC B2948
DTC B2957
DTC B2958
DTC B2960
DTC B3031
DTC B3033
DTC P1626
DTC P1630
DTC P1631
DTC P1632
Do you know what DTC'S are , these would point to an area of trouble an to a fix .
1helpful
I have a 2003 chevy malibu that won;t start. When you turn the key to on the Theft System light comes on steady ( no flashing). I t used o go into this mode periodically where the Theft System light...
I have had the same problem. This has happened to me three times in the past nine months or so. Per the owner's manual, you turn the key to the on position and wait about ten minutes. This resets the system and when the "Theft System" light goes out, it starts right up. I did this each time and it started right up.
97 chevy suburban won't start I believe it is
does the motor crank when key is turned?If so check for a spark at the plugs.Get an auto electrician bypass your alarm
1helpful
2answers
My malkbu classic won't start. The guy at the grage says its a key sensor. I believe I had this replaced around 2 years ago. Did I miss a recall, or how do I get info regarding a recall?
call the chevy dealership, and ask them if there has been any recalls in the past for your malibu. good-day! or if no good response, ask for the chevy recall center!
I changed engines from a 1996 chevy cavalier to a 1997 cavalier,i don't get any gas or fire won't start
These cars were made with an anti theft security system. If you swapped motors, you may have interupted that system causing the the security to turn off the ijector fuel. Just a thought.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Top Jeep Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Jeep Expert? Answer questions, earn points and help others
