I drill a hole in the outer rim of the old coupling and then using a hammer and punch in the hole whack it in the same direction it turns when the motor is running. That will eventually unscrew the coupling and you will be able to screw the new one on. There is no need to make a big effort to tighten the new coupling up hard, over time it self tightens with use, that's why you are having trouble undoing it. Just screw it up as far as it wants to go by hand.
SOURCE: Any idea where we can get a new jug for a breville blender?
This happened to me recently. Go to this site and order it directly from Breville. They were very fast and customer service very helpful.
http://www.brevilleusa.com/home.do
SOURCE: Broken glass jug on kitchenaid blender model 5ksb2aer4
Look at the underside of the blade shaft. The metal wing nut on the end of the shaft secures the blade assembly to cream coloured plastic blade base. The wing nut also transmits the drive from the rubber coupling on your blender to the blade shaft. The wing nut has a LEFT HAND thread.
The left hand thread ensures the blade assembly does not unscrew during normal blender use.
Firstly disassemble the blender blade assembly. Place a folded tea towel over the blades and hold the blades firmly. If you do not use a tea towel you may cut yourself.
Grip the wing nut with your other hand and unscrew it CLOCKWISE.
Remove the wing nut. You can now remove the blade from the plastic base.
Put the blade assembly in the new jug and offer up the plastic base from under the jug so that the blade shaft protudes enough for you to install the wing nut.
Screw the wing nut ANTI-CLOCKWISE to secure the blades to the plastic base.
Do not over tighten the wing nut; you may have to replace your jug again at some point.
SOURCE: Moulinex Genius 2000 Blender jug -AL20
This may not be a solution but... I have found that the Salvation Army, Good Will, American Vets i.e "thrift shops in general" are a gold mine for things like this. Moulinex machines abound in them.
