Hi Try upgrading to a Higher Wattage
Power Supply Unit (PSU/PSMP) Use Heat Sink Paste between the CPU
and the Heat Sink. Try a more effective CPU Heatsink
and Fan Unit. Check for a build up of dust, dirt
and grime between the CPU and Heatsink, between the PSU/PSMP Fan and its Rear
Grill, between the plastic Front Control Panel and the metal chassis of the
computer case/casing, and in the general case, causing overheating when the
computer is on, preventing the intake of cooling air and/or the venting of hot
air. Avoid using a computer placed on a
thick pile carpet or in a restricted cubby hole or desk or with its rear or side hot air exhaust vents too
close to a wall, restricting the inflow of cooling air and the outflow of hot
air. Check if a misaligned, metal motherboard
mounting point or a loose screw that has found its way to the underside of the
motherboard is shorting on motherboard solder points. I
hope this helps. If
this Answer goes some way towards helping to resolve your Query, Problem or
Fault, please take the time to Rate it. This helps Answerers, like me,
better understand the needs and the point of view of Askers, like you, and
guides us in exploring the best ways to provide the most comprehensive, useful
and high quality Responses and Solutions we can. If you need further help, please do
not hesitate to post another Question or add a Comment to this Question. Thanks for using FixYa.
