Its p5vd2-x u read in wrong way
http://www.asus.com/Motherboards/P5VD2X/#support_Download
SOURCE: No any display in the monitor, no beep of the RAM while CPU fan is running
Check your power supply. It sounds like you have a bad power supply. Even though the computer powers up, it does not mean that it's good. I have had this problem before, and almost 9 out of 10 times the power supply had gone bad. Just try a different one and see. hope this helps you.
SOURCE: ASUS cpu fan kit enquiry
http://pcpartscollection.stores.yahoo.net/comaxiforinp.html
Btw, Iām available to help over the phone in case u need at https://www.6ya.com/expert/stephen_171aeeebef53a898
SOURCE: Compatible Graphics Card for ASUS P5LD2-VM SE Motherboard
Your board is PCI EXpress so as long as you get a PCI express Video card you should be fine. Just dont get a video card with a Faster Bus speed than your Mobo or else its wasted potential, but other than that, ** problem, have fun playing video games :)
SOURCE: Replacing Asus CUV4x Motherboard with Asus p5vd2-vm-se motherboard
Hi eibral2345, sorry but there is no chance the motherboard, Asus P5VD2-VM-SE will run the Samsung memory. It’s the old style 3.3V PC133/100 SDRAM. The new Asus motherboard,
P5VD2-VM-SE uses Single-Channel DDR2 - 667MNz or 533MHz memory. Here is a link to the specs of the Asus CUV4X: http://www.pcstats.com/articleview.cfm?articleid=314&page=3
Here are the specs for the Asus P5VD2-VM-SE MB: http://www.asus.com/products.aspx?modelmenu=2&model=1787&l1=3&l2=11&l3=369&l4=0
Will the new Asus board fit in your case? It should!
The larger measurement is the height of the board.
The Height + Width of the new board is smaller than the older board.
Have more questions?
Good luck eibral2345!
Mike
SOURCE: i lost my motherboard cd...
No problem gopi86,
Just click on this link: http://support.asus.com/download/download.aspx?modelname=A8V-VM%20SE&SLanguage=en-us
Asus has everything listed for download.
Enjoy!
Mike
