Goodman CKL42AR42 Air Conditioner Logo
Anonymous Posted on Sep 04, 2011
Goodman air conditioner not starting - Goodman CKL42AR42 Air Conditioner
  • Horace Gardner Sep 04, 2011
    Need more information. By "not starting", does this mean the inside air handler and the outside condensing unit will not start running when you set the thermostat in the cooling mode and turn the thermostat set point below the room temperature?
Robert
Level 3:
Genius:
  • Goodman Master 1,036 Answers
  • Posted on May 05, 2015
Robert
Goodman Master
Level 3:
Genius:
Answers
1036
Questions
8
Helped
345845
Points
3136
Check the fuse inside the furnace first. If the fuse checks out good, then it could be a component on the outside unit such as a capacitor or contactor coil.
Anonymous
Level 3:
  • Master 767 Answers
  • Posted on Sep 05, 2011
Anonymous
Master
Level 3:
Answers
767
Questions
0
Helped
203984
Points
2143
Hello my name is Heath it will be my pleasure to assist you. First thing to do is go to the furnace take off the lower blower door and locate the circuit board turn the power off to the furnace. In the circuit board there should ba a small car like fuse usually 3 or 5 amps check the fuse it is probably blown replace the fuse with the same amperage fuse and then turn the power back on on the furnace and check the operation of the furnace.
What size capacitor for a cpke42-1b
You will need to call Goodman. I rely can't imaggin how the compressor can start with out a start run capacitor.
What type of start capacitor do i need for a goodman ckl 30 1L
Air Conditioning Compressors are Permanent Split Capacitor motors that use a "Run" capacitor. You can purchase a "Kick-Start" which is a hard starting device.
Goodman air fan hums wont turn
Either has a bad start capacitor or bearings have gone dry, and shaft is stuck. Motor would probably have to replaced.
Blower starts ans stops
May be a short in the wiring or a bad control board.
Top Goodman Heating & Cooling Experts
Paul Carew
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
