Kenmore 44921 Front Load Washer Logo
Marie Trouette Posted on Apr 25, 2006
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore 42990 front loading washer
All works fine, except machine will not fast spin. All other cycles (gentle agitate, fill, drain, timer advance) are fine. Wondering how to test the motor. I'm very handy so don't be shy with the directs. Last desired path is calling repair center. Thank you!
Anonymous
Level 3:
President:
  • Master 878 Answers
  • Posted on Apr 25, 2006
Anonymous
Master
Level 3:
President:
Answers
878
Questions
Helped
1202184
Points
3312
If this is a 417 model your problem might be the pump itself. There is a pressure switch that detects whether or not there is any water left in the tub. If so, it will not go into high spin. Remove the lower panel and check the pump on the lower right side. See if there is any gunk or coins in there by removing the hoses attached to it. Have a flat pan or a bunch of towells ready to catch the remaining water from the tub. If the pump checks ok, the next move would be to check the motor controller itself.
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • 0helpful
    My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
  • 2helpful
    My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
    Hello there:
    If your cycle does not complete or The cycle doesn't advance
    When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
    Kenmore 431423 won't advance cycle, won't agitate
    not sure why he would replace the shocks this is clearly a timer/control issue. Replace the main control
    1helpful
    Will not agitate 110 92587210 Kenmore Washer
    I have 2 words for you: "dog ears".
    the dog aggitation ears are what cause the aggitator to aggitate. Those things wear down and not grab after time.
    Pretty easy to change out. You just need to pull the aggitator out and change the 4 little plastic ears. Good luck :)
    The washing machinge is not completing the complete cycle
    4helpful
    My washing machine is not changing cycles. It fills, drains and refills. It sat unused for 1 year. 12 months ago it was working fine.
    Hi there. I can help you.
    • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. If this is the case, turn off the water and remove the hoses. Check both hoses to be sure the filter screens are not clogged with crud and that the hoses aren't kinked.
    Washer won't wash
    Hi!
    Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    3answers
    Washer will not cycle
    The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
    Washer fills/agitates and stops prior to draining
    If pump works fine or still pumps out water, then it is a timer malfunction. Replace the timer and you should be fine. To locate a part number for your timer, refer to www3.sears.com with the model number off your washer.
    Alexander
    vince
