Samsung HT-DB120 System Logo
sera mavi Posted on Apr 05, 2006
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Protection displayed and shuts off
When I press the power button Protection is displayed for a brief second and then the unit shuts down. Pressing power button does not do anything afterwards for a while. The fan works through that brief moment when Protection is displayed.
  • 3 more comments
  • sera mavi Apr 06, 2006
    This happens even when no speakers are connected to the unit. I just plug in the unit, press power, and it happens.
  • mrsmanaiza Apr 20, 2008
    i turn on the system it reads protection and then turnd off
  • Anonymous Jul 16, 2008
    i power up the system it displays F61 for a second and then shuts down. it happens even when the speakers are disconected.
  • enc78 Dec 26, 2008
    receiver plugged in with no speakers the display screen flashes push power protect. how do i fix this problem
  • bella3984 Apr 27, 2009
    my ht-ds490 as doing the same thing even with nothing plugged in
svn_blogger
Level 1:
Problem Solver:
  • Contributor 17 Answers
  • Posted on Sep 06, 2009
svn_blogger
Contributor
Level 1:
Problem Solver:
Answers
17
Questions
0
Helped
11591
Points
27
I had a similar problem and managed to fix it. It is not necessarily your case, but in mine the output filter capacitor in the central speaker channel got broken - it had a crack on its body. Replacement of the capacitor fixed the shutdown on protection.
Another question is what damaged the cap. It could be just a bad device or there was something overlooked during development of the home theater. Preliminary I consider placement of the capacitors as a possible problem - they are too close to the output inductors which can get relatively hot even at normal working condition. Anyway you can look at my solution - I posted it: http://craftsman-hambs.blogspot.com/2009/09/samsung-home-theater-ht-x40-shut-down.html
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Sep 22, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
5771
Points
7
Http://lemurt.wordpress.com/2008/08/18/defenition-of-waranty-void/
this is y fix to it. Had the same problem, but now it works perfectly. samsung ht-x30.
Anonymous
Level 3:
An expert that gotĀ 10 achievements.
President:
An expert whose answer gotĀ voted for 500 times.
  • Master 3,130 Answers
  • Posted on Apr 05, 2006
Anonymous
Master
Level 3:
President:
Answers
3130
Questions
5
Helped
1650341
Points
8439
Are all the speakers good?? discont all the speakers and see if all the lites come on. Then shut off and start to connect one at a time untill the unit shuts down and then you know you have a shorted speaker. If the same thing happens you probably have a power supply or an output stage falure and this should be serviced by someone who is quilified to work on stereos
Anonymous
Level 2:
Novelist:
  • Expert 130 Answers
Anonymous
Expert
Level 2:
Novelist:
Answers
130
Questions
0
Helped
238021
Points
215
Usualy the fan kicks on when it reaches a certin temprature because there is somthing inside overheating. If the fan cant cool it fast enough it trips a breaker and shuts down to protect it from blowing out. Somthing is causing it to over heat and a shorted or blown speaker can do this. Speakers are a just a coil the + goes to one side of the coil and the - goes to the other side. When they are over driven (to much bass or to much volume) the coil can burn apart or ground out and cause a short. These are usualy the first problems. Another thing that happens is the circuit in the speakers blow up and you smell a nasty peanut butter smell. These are the frequency caps blowing up and the electrolyte in them stinks like peanut butter. So if your speakers smell like a peanut butter and jelly sandwich you rocked out a bit to hard. :D
2 Related Answers
Anonymous
  • 210 Answers
  • Posted on Jun 09, 2008
SOURCE: Help
Take every single cable out of the unit, now power on the unit.
If the power protection still shows then there is an internal fault, usually a short or a component defect.
If it powers on ok, switch off and insert 1 speaker at a time and power on the unit until the protection mode comes on again, the last speaker you have put in has overloaded it for some reason, also as you are trying each speaker use the volume and bass controls to see if there is an internal overload.
Thats as much as I can offer you until you narrow the fault down to the unit or one of the speakers.
Cheers
Anonymous
  • 3 Answers
SOURCE: Protection displayed and shuts off
Hey guys! Im glad you found my solution on my blog, and posted it here. I hope you ccan fix yours, or get it replaced on warranty. Im happy to help you with anything, the capacitors i think was 4,7 uF, 100volt, not sure.
Here is the link to my solution: http://lemurt.wordpress.com/2008/08/18/defenition-of-waranty-void/
:D
/ lemurt
Screen froze
Hi Robert,
Please follow this...
  1. First of all, take your phone and press the power button; the select "power off".
  2. Wait while your phone is shutting down; wait a few seconds and then proceed.
  3. Now, press the volume down and power button at the same time for 2 or 3 seconds until the LG logo appears on the display.
  4. Then release the buttons and then press and hold them again.
  5. Keep pressing the buttons until the recovery mode menu will be displayed on your LG G2.
  6. That's it.
  7. If you then want to go back to Android OS, just select "reboot system now".
Feb 28, 2016 • Cell Phones
tip
ERROR CODE AND SERVICE MODE
Service tool modeHow to access
1. Select [SRV-TOOL] in Service Mode.
2. Press [OK] button on the remote control.
Display of SOS History
SOS History (Number of LED blinking) indication. From left side; Last SOS, before Last, three occurrence before, 2nd occurrence after shipment, 1st occurrence after shipment.
This indication except 2nd and 1st occurrence after shipment will be cleared by [Self-check indication and forced to factory shipment setting].POWER ON TIME/COUNT
Note : To display TIME/COUNT menu, highlight position, then press MUTE for (3sec).
Time : Cumulative power on time, indicated hour : minute by decimal
Count : Number of ON times by decimal
Note : This indication will not be cleared by either of the self-checks or any other command.Exit
1. Disconnect the AC cord from wall outlet.
Hotel mode
1. Purpose
Restrict a function for hotels.
2. Access command to the Hotel mode setup menu In order to display the Hotel mode setup menu, please enter the following command(within 2 second).
[TV] : Vol. [Down] + [REMOTE] : INPUT (3 times)
Then, the Hotel mode setup menu is displayed.
3. To exit the Hotel mode setup menu Disconnect AC power cord from wall outlet.
Troubleshooting Guide
Use the self-check function to test the unit.
1. Checking the IIC bus lines
2. Power LED Blinking timingCheck of the IIC bus linesHow to access
Self-check indication only:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [OK] button on the remote control for more than 3 seconds.
Self-check indication and forced to factory shipment setting:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [MENU] button on the remote control for more than 3 seconds.
Exit
Power LED Blinking timing chart
1. Subject
Information of LED Flashing timing chart.
2. Contents
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
FOR MODE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE DROP DOWN MENU
2helpful
3answers
Power problem
If the protect function works but is causing you problems, cancelling the protection function should help, and it will be possible to enter the self-diagnostic function mode. This should disable all functions of the protection mode, excluding the 'excess electrical current detection' feature.
While pressing the "Tone Control" and "Info" keys, try pressing the power key to turn on the power. Keep pressing those 2 keys for 3 seconds longer.
this should activate the Self Diagnostic function, with your Protection Mode disabled.
in this mode the 'sleep' section on the tv's fluorescent display flashes to indicate that the mode is properly activated.
just be very aware, this function is normally there as a safety feature and i cant guarantee that disabling it altogether won't cause other problems down the road. best of luck!
Led display shut down when the detector detect an alert
You have the unit in dark mode. Press the Dim/Dark button again to get the unit to full brightness. THe unit has 3 levels of DIM. First the unit is at its full brightness, pressing the dim/dark button will dim the display and the unit functions normally. Press the Dim/Dark button again will futher darken the display but when the unit alarms the display is turned off and remain off during the alert. After the alert is over the unit waits 20 seconds of no alert to turn the display back on.
2helpful
2answers
the solution is get rid of it fast , i had a samsung dvd player that did that then it caught on fire , pretty scary,lucky i was there when it started to smoke up
Panasonic PT-40LC12
hi...
Panasonic lamp timer reset procedure
1. Press the power button to turn the unit on.
2. There are 3 choices for this step, depending on the housing part number:
A. TY-LA1000, TY-LA1500 or TY-LA2005 While pressing the VOL- button on the projection display, hold down the PIP or SPLIT button on the remote control at the same time for more than 5 seconds.
B. TY-LA1001 or TY-LA2006 While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
C. TY-LA2004 While pressing the VOL- button on the projection display, hold down the MUTE button on the remote control at the same time for more than 5 seconds.
3A. When the reset procedure is complete the the following screen will appear: LAMP TIME WAS RESET TO 0 (this screen may be different from the actual screen)
OR
3B. The POWER and LAMP LED's on the front of the unit will flash for 5 seconds. (TY-LA2006)
When the lamp time reset is finished, the LAMP indicator goes out. It may be necessary to attempt the procedure several times.
Help
Cheers
1helpful
The protect message indicates that the output amp section has a problem. Normally this requires the replacement of the output transistors or the output amp pac. Expect the repair cost to be about $20-$60 for parts plus the local labor rate.
Dan
1helpful
2answers
:D
/ lemurt
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
