Make certain you are using the right connection cables first off. Then check the settings on both the TV and Sony. For example it has to send bitstream signals to get Dolby on your receiver . PC signals will not work.
Sometimes these units have the ability to switch the speaker off and on. Look up the speaker settings in the manual.
As each channel in the unit will be separately driven the power amp for the center channel could have failed, but I think it's unlikely unless you have had problems with the sound on it before, or connected it wrongly causing a fault.
Look in the circuit board area where the power cord mates with it for capacitors that have bulging tops (instead of the flat tops that are normal). If you see even one, you need to replace all the large capacitors othe power supply section (normally around 5 or 6).
I have a problem with vintage reciever Sony STR-11L. Power transistors were replaced and I dont know what were original ones. Sound is no good and radiator is hot-I think problem is in replacement. Can anybody help me with?
Try, the fusível, if not work, try off the outlet 2 minutes, and plug in wall again.
-Verify the Voltage Selector too.
If after does not work, you need a techinical assistence.
