Instruction to assemble a clipper blade.Above picture Socket
Spring Tension
Place Socket on Spring Tension like this
Slide Socket back as shown in picture
Turn Socket & Spring Tension over Make sure Socket is slide back
This is Call a Blade Guide Make sure the blade Guide is on the Spring Tension
Make sure blade guide is on like picture above, Now place Socket & Spring aside
The comb Blade Place comb blade as picture above
Place cutter blade as picture above, making sure cutter blade smaller blade is on the
comb blade Rail.
Hold the blade like this Finger on top and Thumb on the bottom
Turn blade over like this while still holding the blade together
Place screw as shown
Screw in the screw don't tighten leave loose.
Now that you have the 2 screw in and not tight place the blade like this You need to hold the blade
with one hand and with your Philips screw driver tap the cutter blade back lightly until the cutter teeth are 2/32 back from the comb blade.
the cutter blade which is the smaller blade is back 2/32 from the comb blade which is the bigger blade. When this is done by holding the blade together with your finger & Thumb
Tighten the 2 screws tight
Your blade should look like this when done correctly
We hope this was helpful when assembling a clipper blade.
