Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
Posted on Aug 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Won't stop filling up. Water continues to flow without stopping for cycles
Anonymous
Level 3:
  • Master 2,341 Answers
  • Posted on Aug 28, 2011
Anonymous
Master
Level 3:
Answers
2341
Questions
Helped
636174
Points
7414
Their are 2 possibilites causing it to overflow
1) the water inlet valve that the hoses from the house plumbing attach to is sticking open,when it sticks it will stick open regardless if thier is power to the machine or not,so to determine if that is the problem,start the washer and quickly unplug it,if the water continues to fill, that valve is sticking
2) the water level switch is defective,do the same as far as starting it,if the fill stops when power disconected it's the water level switch that is in need of replacement
Good luck, i hope this helps.
Gene
  • Randy Rodgers
    Randy Rodgers Dec 03, 2015
    Thanks Gene very helpful
Aeg favorit 40010vi dishwasher won't fill with water
I have a similar issue on oko favorit 50700. I have checked the flow from the inlet hose into a bucket and it really seems ok, so I think maybe a problem at the inlet to the machine? Plea update if you get a fix!
GE Super Capacity Plus won't stop filling
Does it stop if you stop the cycle or do you need to turn the valve off?
What is the complete model number of your unit?
1helpful
My samsung top loader washing machine sw65v9w won't stop filling with water
If the water stops when you stop the cycle, then the pressure sensor is at fault. If you need to turn the water supply off to stop it, then the water inlet valve is at fault.
Doesn't fill
Possible that the water level sensor is faulty as it tends to indicate before the level has reached thereby starting the rinse cycle.
Usually this can be due to faulty level settings or fault in the pressure switch as it can be acting too fast. It will be best to clean the inlet valve and check the flow , test the water level sensor and see if this works by blowing into the diaphragm.
The water won't stop filling up the tub causing it to over flow.
it could be the pressure chamber is blocked up with old hard soap or the pressure switch is jamed
1helpful
Whirlpool Sm8525079 Rev fills up with water, but won't agitate.
Your lid switch has a fault, Sometimes the switch can bend which means that it won't always operate.
I have a Kenmore Elite He3. It won't complete any wash cycle without stopping and displaying HF. I can restart it but it continues restarts the wash cycle again. Therefore a Heavy Duty wash cycle of...
Hi
Error code FH appears when No water is detected entering machine or Pressure switch trip is not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display. If there is no water entering the unit then make sure that the inlet valves are working fine. You may need to check the continuity at the inlet valves. If the valves are fine then check whether inlet water hoses as they might be plugged. Also check for inlet water screen at the valve. However, if the water is entering into the washer then the Drain pump might not be working. Also inspect the Pressure Switch hose whether it is in good condition and properly connected to Tub and Pressure switch. Also check hoses for leak and inspect the flow meter. Hope this helps...
Daniel
GE Spacemaker Washer/Dryer. Model # DDPI380GAMWH. Water won't stop filling. It continues to fill during all cycles. Fills during agitation. Agitates inproperly. It agitates in short pulses as water...
Thanks for choosing FixYa and welcome. This sounds like a problem with the water level switch in the washer. It controls the amount of water entering the tub. It is probably defective. You may want tomake sure the switch is getting power first by testing the wires with a voltage meter.
Whirlpool Estate Washer will not stop filling.
There is a fill switch that is not being triggered. Find out where that is. The dog hair could be the culprit. This switch is but cutting the tank fill. God Bless John
Alexander
vince
