ASUS Eee 4G Notebook Logo
Anonymous Posted on Sep 07, 2017
My friend have reformat my ee pc4g series laptop, but after that, the audio HD device was being detected but could not complete the installation, it says that: the hardware was not installed because the wizard can not find the necessary software, I already downloaded realtik audio driver, but still the device is not working, How do I solve this? by: [email protected]
  • ahmadkasra Sep 07, 2017
    Hi.plese follow this step and check if solve ur problem
    Right click on my computer icon then select device manager and check if u see ur audio hardware instal right click on it and delet it and let it to that install itself
Kenny
Level 1:
New Friend:
  • Contributor 22 Answers
  • Posted on Sep 14, 2017
Kenny
Contributor
Level 1:
New Friend:
Answers
22
Questions
0
Helped
3295
Points
58
Do what the other one above suggested if that does not help go to device manager uninstall the driver then restart computer that should fix the issue if still does not work this go back to device manager and uninstall the driver and then manually install the driver you downloaded from the website(make sure its the correct driver)
Should be good to go have a good day!
5 Related Answers
Anonymous
  • 113 Answers
  • Posted on Feb 26, 2008
SOURCE: ASUS A3AC HELP
Here are the audio drivers for Windows XP:
http://support.asus.com/download/download.aspx?modelname=A3Ac&SLanguage=en-us
Realize that you also need to load the Microsoft HD audio drivers as well.
Christian Fernandez
  • 135 Answers
  • Posted on Sep 17, 2008
SOURCE: ASUS A6 Series Entertainment Notebook VGA, Modem & Audio Devices
Check out this link: http://support.asus.com/download/download.aspx?SLanguage=en-us
Just select your exact model.
Hope this helps.
Anonymous
  • 12 Answers
  • Posted on Jan 08, 2009
SOURCE: can't play a song, computer says a problem with my sound device
here you can download the audio driver(For Win XP):
http://www.2shared.com/file/2978932/261e8259/Audio.html
shadow
  • 490 Answers
  • Posted on Jun 01, 2009
check this link and find your model and operating system. download.
Anonymous
  • 12 Answers
  • Posted on Sep 04, 2009
SOURCE: can not install sound card on Asus F5R
alrighty, check your bois see if your audio device is disabled, also check in device manager if theres any multimeda devices that have no drivers, then go to sounds and audio devices in controll panel and select the device and theme for your pc some times Windows has a dedede moments hope this helped ^-^
2answers
Hi i have compaq 6720s after re install of window xp my sound is not working I m gating msg no sound device pls help me
If you have not run Windows Update, this is the place to start. Go to Start - Programs - Windows Update at the top of the menu. It will detect any updates required or optional for your PC. It will also check for any hardware updates that are available for your system. You should select to install of the hardware updates and see if there is an update listed for your sound card. It will be obvious if there is one. If not, let me know and we will go get this from a different angle.
4answers
Realtek audio driver for asus eee pc 4g surf
Go to asus website. They have all the drivers.
Can get the sound to work says no audio device is installed
Download and install the latest driver for the audio device in the computer. Most now have a HD audio driver. During the installation the device is detected and installed.
Please let me know how you do with it.
~ Spoem
1helpful
2answers
Audio device is basically not recognizable...driver won't install
Unplug power take the main batter out of the unit. Then hold the power button in for 1 full minute. then put the battery back in and plug power back in and turn on the computer. See if you have sound. If not go to Device manager and see if it shows up under Sound and Video. Should be something like HD Audio. if not the go to ad and remove program and remove sound driver and reboot. Got to http://support.dell.com and download the Audio Driver and install it.
1helpful
2answers
My sound is not working. Says correct driver is installed for Realtek HD Audio but I get message: "This device cannot start. (Code 10)." Also, I think it is related as my sound stopped working when I...
Actually you are not completely install your Realtek HD Audio. Continue to install with that "unknown device on high definition audio bus"by using your TOSHIBA Utility Disc you have. Let the system search the driver from the CD/DVD inserted. Then follow the instruction to complete your sound installation.
Tell us more what next is the problem unresolved but i'm sure that is works.
Hope this might help you.
Toshiba P30 - I can't complete the reformat/restore operation
pull out the cd drive and reboot. then go to programs folder and un install any new dvd or cd programs that where just installed. reboot . then try to install your drives again
Iā€™m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
2answers
Audio Troubles
hi!!!!
there was a corrupted file in your windows registry or in windows system 32
the solution for that is to reformat your operating system
back up all your important files!
1helpful
3answers
Driver installation failed: Could Not find the media device for this driver
Most of the downloads for a Compaq Presario V3000 CTO Notebook PC maybe found here. Specifically, latest audio drivers for Vista is here while for XP is here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
3helpful
3answers
Everex Stepnote VA1500V, NO AUDIO!!!!!
Hi, you need to download and install the drivers for your audio. I believe these should work for ya. CLICK HERE
20helpful
3answers
Logitech USB headset no sound
Have you tried changing the Audio Device that windows is using?
Under the Sound and Audio Devices in the ontrol Panel. Under the Audio tab, try the Default Device under Sound playback. Change this to the headphones.
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
