Question about Refrigerators
Change doors from left to right - Refrigerators
  • Refrigerators Master
  • 8,220 Answers
Providing yours is a reversible model the job is fairly easy. You start from the top. Pop the hinge cover off and remove the top hinge screws. Look over to the other side first and see if their are some remove able plastic plugs so ya can move the hinge over. Remove the top hinge and the top door lifts off. Move the handle to the other side. Next remove the middle hinge and lift the bottom door off the base hinge. Be careful not to loose any spacers or plastic inserts that might be in the door. Move the handle over to the other side. Move the base hinge to the other side. Remove the decorative plastic plugs from the center hing and put them in the holes you just took them screw out of. Then remount the bottom door and center hinge. Next place the top door on and the top hinge. As you tighten down the top make sure the door is level. The hinge has slots in it that allow a lot of wiggle room to get the door level. Tighten down the screws as you hold the door in place for a sweet fit. Snap the hinge cover back on.
Optional: To make the doors close a little tighter raise the front legs slightly to make the door hug the ice box tighter.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Aug 26, 2011
  • 57 Answers
Depending on the brand, this "may" be possible. Look for a mounting bracket area on the side you want to change to. Is so, have someone help you, two person job!
Tips Provided by: www.HoustonRefrigeratorRepair.com Brian Gillespie (GOFAR Services, LLC)
6ya staff
SOURCE:
After changing the right door hinge on my bosch hbl455auc the door closes but the upper oven door is 1/8 lower at right top than left. How can I realign the door to level?
There are adjustment screws or bolts on the hinge attachments to the oven. Loosen them and adjust the door using wedges to hold the door in place.
Jan 12, 2013 | Bosch HBL 455 Stainless Steel Electric...
Switching door sides
some model you can, some you can't....if there are pre drilled holes with plastic plugs on the opposite side you can....you will need to purchase hinges and maybe handles.
Jul 24, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Help . Change doors from right to left opening
first remove the door from the fridge, remove the hardware connected to the fridge, on the opposite side should be rubber or plastic caps covering some bolt holes. remove caps and install top of hinge transfer everything you see on the left to the right
Oct 21, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Changing Right Hand Door Fridge to Left hand door
This is a simple job remove both doors and switch them from left to right.You will have to remove the plugs from the holes where the hinge go be sure to adjust the gap between the doors and put the plugs back in the place where the old hinge screws were.
Hope this was helpful.
Sawdust46
Aug 19, 2009 | Refrigerators
Washer door opens with hinges on the left
nope sorry but all front load washers are built with a locking system on the door and that makes them impossible to change the door swing.
the only thing you can do is move the washer and dryer position by getting longer hoses and venting so you can have the washer on the left and the dryer on the right.
Dec 28, 2008 | LG Washing Machines
Cannot reverse door on Electrolux fridge freezer
Basically they needed to supply an additional door mount for the left hand side of the door as well as the right hand side. Problem now sorted. Poor instructions in the manual didn't help here!
May 26, 2008 | Freezers
Refrigerators Logo
192 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
