After holding down the component key, and pressing a number, it blinks four times, instead of once. What's going on?
Took me awhile but I figured it out
ok
Put your TV/DVD/VCR on
hold in what you want to program TV/DVD/VCR BUTTON
(you dont need codes or anything)
then while holding in what you want to program (TV, DVD, VCR) hold in ON/OFF
both at the same time
when the light comes on and stays on
keep hitting ON/OFF BUTTON
do it slow, when the TV turns off hit the STOP button at the bottom
then hit the button you just programed
then hit the ON/OFF button, the TV/DVD/VCR will turn on
if it doesnt work, repeat. make sure you hit the stop button when the
TV/DVD/VCR shuts off, if you hit it an extra time while the TV/DVD/VCR
is off it wont work.
took me about 30 mins to figure it out.
I have a sony RM-V202 i need help 2 set it 2 my tv my tv have a d on it
I need the code for a rca rcr32723 3-device remote control
Its easy look at the video
Okay here's what I tried.I have an older Rca tv, I was using a generic remote.. I recently moved to a new apartment. I could no longer use this remote with my tv..It just wouldn't work. I tried all night long to reset the code..My Final conclusion was. Get tv model name and number. google it to find the original remote number and picture perhaps..Then I found places that sold them google (again).$35 on up and mostly obsolete. So, I decided I would take this picture of the remote to the flea mkt, and I found this remote for one dollar...I brought it home cleaned it up with damp clothe and tooth pick..Works like new, I feel kinda smart right now..LOL..Well another choice would have been to lug it to a tv repair shop and have a technician set it up ...But I saved a lot of money..and I am real glad.. Good luck..!!
FIND and Download an Operation/Owners manual for the Remote or in my case the VCR the remote came with, and look for codes there.
Make sure that u hit the device (i.e. tv ) key after u hold the set-up key down. then input the code after the set-up key is released.
Heres a website with the codes. http://download.ethomson.com/english/UNBRANDED/ACCESSORIES/IB/CodeListADR560660.pdf
I ORDERED A UNIVERSAL REMOTE FOR MY V5500 VCR/DVD COMBO ... HOW DO I GET IT TO WORK ... IT WILL NOT DO ANYTHING ... HAVE THE DVD PACKAGE OF 24 HOURS AND CANNOT GET THE DVD TO ADVANCE TO NEXT HOUR ...
Hi maybe the batteries are weak..?? change them OR the remote is telling gently that you have entered a wrong code here you got all the codes you need: http://remotefinder.rca.com enjoy
[1] Manually turn on the component
you want the remote to control.
[2] Locate the enclosed Code Lists.
Find the list for the component you
wish to program. Find your
component's brand. You will see a
listing of four-digit codes for each
brand. If your brand isn't listed, use
one of the Code Search methods to
program the remote control.
[3] Press and hold the component key
(TV, VCR•DVD, SAT•CBL) you
wishto program. The illuminated
ON•OFF key turns on and
remains on. If you release the
component key at any time
during the Direct Code Entry
procedure, the illuminated
ON•OFF key blinks four times,
and the process is exited.
[4] While holding down the
component key, consult the Code
Lists for the four-digit code that
corresponds to your component's
brand and use the number keys
(0-9) on the keypad to enter it.
While you are pressing the
numbers, the illuminated
ON•OFF key turns off.
[5] After the fourth number is
entered, the illuminated ON•OFF
key turns on. At this time, release
the component key. If the
illuminated ON•OFF key turns
off, you have entered a valid code
and have followed the correct
procedure for Direct Code Entry
If you enter a code number that is not
in the Code Lists or you do not follow
all of the steps for Direct Code Entry,
the illuminated ON•OFF key blinks
four times when the component key
is released. This is an indication that
a programming error has occurred.
In that case, repeat the Direct Code
Entry process from step 3.
These are the proceedings with RCA RCR-311 remote control. Most of the RCA remotes will have this process itelsf. OK.
To program your universal remote to control your components
using the Direct Code Entry Method, follow the steps below.
1* Manually turn on the component
2* Locate the enclosed Code Lists.
program the remote control. (Refer
to pages 7 and 9 for Manual and
Auto Code Search methods.)
3* Press and hold the component key
4* While holding down the
5* After the fourth number is
procedure for Direct Code Entry.
OK.
OK.
Direct Code Entry
1. Manually turn on the component you want the remote to
control
2. Locate the enclosed Code Lists. Find the list for the
component you wish to program. Find your component's
brand. You will see a listing of four-digit codes for each
brand.
3. Press and hold the component key (TV,
VCR•DVD, SAT•CBL) you wish to
program. The illuminated ON•OFF key
turns on and remains on. If you release
the component key at any time during the Direct Code
Entry procedure, the illuminated ON•OFF key blinks four
times, and the process is exited
4. While holding down the component key, consult the
Code Lists for the four-digit code that corresponds to your
component's brand and use the number keys (0-9) on the
keypad to enter it. While you are pressing the numbers, the
illuminated ON•OFF key turns off.
5. After the fourth number is entered, the illuminated ON•OFF
key turns on. At this time, release the component key. If the
illuminated ON•OFF key turns off, you have entered a valid
code and have followed the correct procedure for Direct
Code Entry.
If you enter a code number that is not in the Code Lists or
you do not follow all of the steps for Direct Code Entry,
the illuminated ON•OFF key blinks four times when the
component key is released. This is an indication that a
programming error has occurred. In that case, repeat the
Direct Code Entry process from step 3.
i need to get the codes for the remote
I have a philips remote REM110 and i lost my code. My TV is a JVC
please where i can find the code for my remote.
Thank's
I need the codes for my remote , not cheat codes, my roommate threw out my manuel and codes. Please help if you can. My remote is a Phillips universal remote, PM625S. Thank you.
need code for insignia tv
NEED MANUAL
Any body help me out on this one please.
I have a nec lt154 projector without the remote
cant get universal controls to work .
Cant seem to find the codes anywhere
Pleas does any body know the correct codes for this and will it work with a universal control
Many thanks
Rick
how do you set remote for symphonic trv
i can not find a code
i cant find any codes for my tv its a sharps
rca universal remote
rca universal remote control
need codes for this remote on a magnavox tv and how to program the remote
i have an Emerson jumbo Universal remote and cannot find the code for verizon fios tv cable box. Can anyone help?
i cant get the remote control to work
need code manual for the device
need codes fro zenite remote control dor flat screen lg brand
NEED CODE FOR DVD MAGNAVOX
magnavox tv code
I have a TOSHIBA TV, need code manual for Zenith ZN401 Remote Control . THanks!
need dishpro 322 code for samsung plasma HP-T5064 50 in tv remote
I lost the booklet that had the codes.I have a panasonic tv and a vcr is a sharp ,could you help find the right codes for both the tv and vcr. Thank you
I have 2 Sony remotes and 2 newer LCD TV's. Why can't I find the program codes for the newer tv's? They are an Astar LCD TV and a Vizio LCD TV. If anyone knows the codes, please let me know. Thanks.
lost the code book rca500 model thank you for your time
when i press the component key and start putting the 4 digit number it bliks 4 times before i finishh
I Need the codes for Universal Remote Philmore PM-RC10?
Can anyone help me out please???
will not work.. the tv light blinks more than once please help
i need the codes for my directv remote for a NEC multisync lcd2335wxm tv
What are the steps to enter the codes?
ineed to find code for my sharp tv for remote #6012
need codes for one for all universal remote control
can not program remote
I can't codify my remote commander RM-EZ4, my t.v. is LG
