I would recommend that you examine the drain hole and physically remove all visible debris. Pour a mixture made from a teaspoon of baking soda dissolved a 1/2 cup of warm water into the hole. Baking soda is great because it helps to break down the cell walls of plant matter (like any algae living in the drain) and removes smells, too.
Then use a long piece of pipe cleaner to push any remaining debris down into the evaporation tray underneath the refrigerator.
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps you to stop the leak,
Gene
Ads by Google' +
// makeBoldAdWords(google_ads[0].line1) + '' +
// makeBoldAdWords(google_ads[0].line2) + ' ' +
// makeBoldAdWords(google_ads[0].line3) +
// google_ads[0].visible_url + ' ' +
// else if (google_ads.length > 1)
if (google_ads.length > 0)
s += 'Ads by Google';
* For text ads, append each ad to the string.
for(i = 0; i ' +
makeBoldAdWords(google_ads[i].line1) + '' +
google_ads[i].visible_url + ' ' +
makeBoldAdWords(google_ads[i].line2) + ' ' +
makeBoldAdWords(google_ads[i].line3) +
// makeBoldAdWords(google_ads[i].line2) + ' ' +
// makeBoldAdWords(google_ads[i].line3) +
// google_ads[i].visible_url + ' ' +
document.write(s);
G_GGL_SKIP += Math.min(google_ads.length,G_MAX_ADS_AT);
return;
var G_MAX_ADS_AT = 4;
//var G_MAX_ADS_AT = 3;
google_ad_client = "pub-8183356113384228"; // substitute your client_id (pub-#)
google_ad_channel = "4447185069+3033438690";
google_ad_output = 'js';
google_max_num_ads = '4';
google_ad_type = 'text';
google_feedback = 'on';
if(typeof G_GGL_SKIP == 'undefined')
G_GGL_SKIP = 0;
google_skip = G_GGL_SKIP;
google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad);
