SOURCE: Where can i find a new chain bar adj screw for WEN 3818 gas saw?
Most older chainsaw adjustments are visible when the saw is viewed from the end of the bar back to the saw. More modern ones are near the bar nuts (side). Lou
SOURCE: Can I get the manual for a Wen electric chainsaw
A manual for a 6016 can be found here:
WagnerSprayTech purchased Wen forever ago
http://www.wagnerspraytech.com/portal/finding_a_product_manual_spray,98115,747.html
I suspect they are similar. Both units are out of production. HTH
Lou
SOURCE: need switch for wen model 6014 chain saw
Jerry answered this. Reposting the same question won't cause Wagner to begin manufacturing a discontinued line.
This unit is out of production. Contact Wagner for any parts availability. HTH
Lou
Testimonial: "Thanks. I will check into Allied or Newark tomorrow. Good ideas. "
SOURCE: Need a adjusting screw and nut for wen electric
Afternoon;
This model Wen was purchased by Wagner many years ago, and neither are producing this model any longer. I suggest you try a local saw shop for a suitable substitute. A Husqvarna or Stihl shop are probably the best odds of success and a weekday afternoon they will likely be most helpful. Take your saw.
The following link is for a 6016 Wagner. it is the only Wagner/Wen OM I have found. Save it to computer. It saves as "download.php" and will not open. Rename it to "AnythingYouLike.pdf" and it will.
http://www.wagnerspraytech.com/portal/download.php?src=portal%2Fdownloadcenter%2Fdateien%2Fspraytech%2FDISCONTINUTED_PRODUCT_MANUALS%2FLAWN__GARDEN%2F0505872.pdf&system_id=97280
The Wen name is again being offered.
WenProducts.com Current models, costs nothing to ask.
http://wenproducts.com/
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
