SOURCE: Frigidaire Affinity ATF6000ES frozen
IF there is an E attached to the 45, it is your control board and the control board would need to be replaced. This is per the "Washer Tech Data Sheet"Hope that helps...
SOURCE: frigidaire affinity indicates 'err' light - nothing else
Dear Abhkss
ngfam at you service,
Sounds like you need service for electronic parts!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
SOURCE: Frigidaire affinity atf6000es1 - control panel locked
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines hope it may for you..............And please rate me if helped
SOURCE: Frigidaire front load washer wont high spin
It doesn't spin
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If your washer pumps out the water but doesn't spin, check these:
For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Hello keisha, thank you for your post!
I understand that your Frigidaire washer is making a buzzing sound until the cancel or start button has been pushed. It sounds like it could be a possible issue within the door either not being fully closed or it could be a defective switch. I would recommend resetting your appliance which can be done by disconnecting power to the appliance for roughly ten minutes. Please comment back if that did not help correct the issue. -Matt
