Changed the FOB battery in mine andf it was the problem, try it!!!
Check fob bat ...check here 2... http://harleytalking.com/login.php?do=logout&logouthash=1313501436-eb7a83064e08c13f62cc323a7bbce4a8d217cd8d
Turn the key to the ignition position. Quickly press both turn signal indicators, until a light on the dash flashes.
Enter the first digit of your 5-digit security PIN by pressing in the left-turn switch the same number of times. So if your PIN is 76543, you should press the left-turn switch six times.
Press the right-turn switch once to store the number and move to the next digit in your PIN code. Press the left turn signal six times to continue, until you get to the end. At the end of the process, the alarm will disarm and the light on the dash will stop blinking. You can now start the bike as normal
warning lights are blinking even though the engine has been shut off
