HP Laserjet M2727nf Multifunction Printer Logo
Posted on Aug 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can i change the page count hp 2727 - HP Laserjet M2727nf Multifunction Printer
gggg
Level 3:
  • Master 904 Answers
  • Posted on Aug 21, 2011
gggg
Master
Level 3:
Answers
904
Questions
Helped
520730
Points
1791
You can't physically change the printer's page count; it's stored in the non-volatile memory or read-only memory. Did you mean check the page count? You can check the page count by printing out a configuration page:
- Press Setup.
- Scroll to Reports.
- Press OK.
- Scroll to Config Report.
- Press OK.
HOW TO RESET PAGE COUNT TO ZERO
The page count on these units is a lifetime count and does not get reset. Larger machines like th P4015 have a maintenance count which is reset when the fuser is replaced.
1helpful
I have just replaced my toner on my HP M2727 nf printer, how do I reset the page count only?
There is no resettable page count on this printer. If you are referring to the counter for the toner level, that is reset by a chip on the cartridge. That chip only works once and if you are using a refilled cartrige that chip should have been replaced. If you refilled it yourself you will need to check on Ebay to find a replacement chip. If you bought a refilled from someone else, take it back and get them to change it. If you bought an OEM HP cartridge and it does not reset the count then call HP as the guarantee their cartridges.
Need to reset the page count after changing out the formatter board.
The page counts and serial number on these units cannot be adjusted or overwritten. You are stuck with the zero count if you installed a new formatter, or the page count on the formatter if you installed a used one. Just put a label on the back that says, formatter changed at XXXXX pages.
10helpful
HP 2727 scans first page as letter size and all other pages as legal size. I want all letter size.
Solution found: Change the scan default format to Tiff, but then save the document as PDF on the workstation. We think this is a newly discovered but unintended feature of the newest hp scanner software package.
1helpful
How tdo i print out number of copies my hp laser jet nf 2727 has done
Hi
You go to the Main Menu on the physical printer, then you look for reports , hit enter and finally look for "usage page"
This will show the number of copies you have printer with the unit
Laserjet 2727
Why would you offer a smart *** comment to a potentially legitimate question? I have the same issue after replaceing the formatter board, the printer is reporting SN12345678 as the serial number.
1helpful
My hp psc 1310 series model No. 1315 printer insists in placing the number 4 in the copy count of my advanced document page, and this overrides any other count number, so I always have to reset this number...
Go to printer and faxes, right click on the printer and click on Printing Preferences, check if you have any option for count in there as changing the printer properties in this was makes the changed permanent.
2helpful
Page count
Depending on exactly what model LaserJet you have, you can print a Self-Test page or Status Page when you change the toner cartridge that will give you a page count.
k24674
Grand Canyon Tech
Grand Canyon Tech
