Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Hi
If its rattling check the drum for anything
caught in it.Washing machine noise is not only annoying, it can also be a sign
of serious damage. When armed with a few tips, you can determine what problem
may be causing your washing machine to rattle, and what you can do to stop it.
Check for drum bearing failure if your washing machine is noisy on the spin
cycle. Drum bearing failure is common when the bearing seals start allowing water
to enter. You can take the belt off and spin the drum by hand, and if the drum
rumbles, replace the bearings.
Turn the drum by hand and listen for loud
noises. If the drum itself is split or the 'spider' is corroded, broken or has
come apart from the back of the drum it will create a loud noise on every turn
of the drum. (When the bearings have gone bad, the noise is constant the entire
time the drum is spinning.)
Look for obvious dents and creases in the
drum or look for coins or small objects stuck inside the tub underneath the
drum when a horrendous noise is made while clothes are in the tub.
Clear the water pump from obstructions like
coins or small objects when a noise occurs while the washing machine is
emptying water.
Remove the sump hose and look for bra wires
if you hear a light scraping noise when the drum is turned by hand. You can
also check to make sure a wire isn't poking out of one of the holes in the
drum. In this case, you can pull the wire out easily with pliers.
Take the belt off and run the motor alone if
you hear a high pitched squealing noise to check for motor bearing damage or
wear. If you still hear the noise without the belt, it's the motor bearing.
Please get back to us if you have further
query or else please accept the solution.
Thanks for contacting fixya.com
