My TV is Sony FD trinitron KV32LS60U
A private TV Engineer had visited me to evaluate the problem.
Parts required are transformer and tube.
He cannot find a replacement tube.
Do you have the tube and can you repair my TV?
usually after 4 or 5 yrs EHT ( transformer that supplies voltage to tube ) becomes weak - then TV won't get ON.. means no picture no sound but LED blinks - in some TVs along with EHT 1 or 2 components like resistor, transistors, etc will also gets deffective - so solution is TV circuit board has to be checked to find whether only EHT is deffective or other components are also deffective - price of EHT will be between Rs.250 to Rs.600 - iam service engineer (computers, laptops, printers,etc) - bangalore - domlur - 09986222774 - [email protected] - if you are in bangalore then you can call me for service
How many red flashes? Mine is flashing twice every 5 seconds and ended up getting a tv engineer to have a look. He has confirmed a faulty transformer approx. Ā£120 to replace
Hi, This is picture tube related problem and we call it incorrect white balance. Adjust Screen Volts of picture tube and control knob wold be located on flyback transformer. If you have knowledge about tv and know that tv contains high voltage and you can take care of that then do it yourself or ask local tv repairman to fix it. Thanks.
no ....the tube will end up after 20 yrs in 10 yr old sony... it is worth if u fix it. randomly going black means...horizontal driver trans former is the problem..or any loose contact with the 110 volt supply to that transformer,,or any loose contact with line o/p transformer.. (horizontal driver transformer may be gone then tv behaves like this) if any other parts gone tv wont come back.... there may be a loose contact call a service pro..
The first one is to check variation of power supply out puts. meaning power supply is not giving constant voltage outputs. Mostly caused capacitors changing values.
If the power supply tests okay, then check second option, the capacitors around the line transformer. A line transformer is a round transformer with a red cable going to a tube of your tv.
Ur high voltage is dead or dying.The FBT call the Fly Back Transformer is dead or dying.U can tries unplug the tv about an hour,might get the high voltage back temporally will happen again later.The big block of plastic with the red wire with a cap to ur CRT(tv tube).That ur prob.
Ur high voltage transformer it dead.The big block of plastic with the red wire with a cap hook to the CRT(ur tv tube).It call the FBT,
the Flyback Transformer that thing it dead.
your tv has a problem inside..the supply that is going to the tube was been cut out... only the servicemen can do fixing your tv... there is a deefective parts...
