HEWLETT-PACKARD HP TouchSmart 300-1125 Tablet Logo
Posted on Aug 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Computer (HP Touchsmart 300) shuts down after 15 or so minutes. Like someone pulled the power cord, Will not restart unless power cord is pulled out and put back in. I can see a steady green blinking light on the motherboard through the heat vent.
Samuel Appiah - Adjei
Level 1:
  • Contributor 3 Answers
  • Posted on Mar 25, 2014
Contributor
Level 1:
Answers
Questions
Helped
861
Points
My hp touch-smart 300-1125uk wont turn nothing moves, not even the fun. when i plugged in the ac cord i see a green light beside where i plugged in ac cord. but immediately i press the power button the green light goes off. unless i pull it out again and Waite for about 30 seconds then the green light comes back again. please i need help
Anonymous
Level 3:
Brigadier General:
  • Master 3,513 Answers
  • Posted on Aug 10, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
3513
Questions
0
Helped
867857
Points
10095
Hi
By any chance does your power supply have an on/off rocker switch on the back? Is it on? I don't mean a red voltage adjustment switch, however. If that isn't it, do you have access to another power supply to install and test? As unlikely and coincidental as it might seem, perhaps the power supply is the problem and needs replacement.
Pull off the main 20/24 pin motherboard power connector then using a small wire or a paper clip connect the green wire with one of the black wires on the 20/24 pin plug, the psu should fire up and the drives will spin up, if not then the psu is dead. When you do this test there needs to be at least one hdd/odd connected to the psu since most psus have minimum load requirements to run.
Some PSUs have a rocker switch on the back that cuts the power, be sure to check that out too.
Check this helpful link to test the PSU:-
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
1helpful
How touch pad that has been flashed over to android and at first it would not charge because I did not have the right charger now it will not charge at all and is taking me back to the flash cyanogen
Touchpads are really sensitive to the type of charger and cable that is required to charge them. I have had trouble charging mine in the past, but the best form of charger appears to be a touchstone.
It might me worthwhile getting a specific USB charger for the Touchpad that provides enough output. A normal phone charger does not have sufficient power.
Quote from another source:
If you have connected your HP Touchpad to the charger only to find that a charging symbol is perpetually displayed, you will probably need to reset the tablet.
This is done by holding the power and home buttons at the same time for around 15 seconds. During this time, the tablet should shut down, restart and then boot into the installed operating system - albeit with a very low charge.
Mar 21, 2015 • HP TouchPad
My hp touchsmart 300 ran a idagnostic and an error message says my touch screen was blocked
1, Activate or reinstall the touchscreen driver in Device Manager. Find the Device Manager in the Windows operating system. Highlight the Human Interface Devices list.
2, Right-click on the touchscreen device and select Enable. If the option does not display, proceed with the next step.
3, Select the Uninstall option to follow the on-screen prompts fo software removal.
4, After a while, install it based on the on-screen instructions.
Where to insert a SIM Card in hp touchsmart tm2 1002tx model laptop?
1, Make sure that the device is turned off. Pull the card tray from the left edge of the device.
2, Take the tray out and insert the SIM card into the slot. Check if the card is inserted properly.
3, Press the tray until it snaps into place.
My hp tx2 tablet pc turns into safe mode and running so slow
Follow these guidelines:
1. Turn a power-off computer on or reboot a running computer.
2. Quick press the F8 key on keyboard before Windows starts, after hearing a beep sound you will be taken to Windows Advanced Options Menu instead of the normal loading page. If it doesn't work on the first try, just reboot and try again. And Select normal loading option.
Fix windows internal errors and corrupt registry to avoid such types of errors in future. I would suggest to use system utility tool Reginout.
Itunes syncing problems
I met some similar problem too with itunes. But did you try other third party software to transfer your songs or photos? Maybe you can have a try. If so, look this:
3 Ways to Transfer Music from iPod to iTunes Library If the problem still exists, you may have to reinstall your computer OS.
Hp touchsmart 300-1125 will not boot, it gets to the logo screen and stops
1, Disconnect the power cord and switch off the computer. Tap and hold the power button for 5 seconds.
2, Switch on the computer and reconnect the power cord. Turn on the computer and tap the F10 key for about every 5 seconds.
3, Press the F5 key and this restores the default settings. Tap the Enter key for the changes. Press the F10 key for opening the Save and Exit window.
4, Tap the Enter key and this saves the changes and restarts the computer.
I have an HP Touch Smart 300 and when the Caps Lock is on and the Number Lock is off there used to be a on screen indicator showing me. I have recently made some changes to my pc and now that light wont...
1, Choose Start and type MS configuration.
2, It asks for Allows User Account Control and select Yes. Choose the Startup tab and remove checkmarks for Desktop keyboard.
3, Restart the computer.
Microsoft Windows Xp professional Version 2002 Intel Pentium M processor 1.80 GHZ 197 MHZ 1.00 GB of RAM not recognizing any usb port
Hello
I am not saying this is the correct solution for this problem, but it works for me every time.
First shut down the computer and unplug the power cord for about 5 minutes. Then boot up the computer again with the USB device plugged in. If this does not work, plug the USB device into one of the back ports of the computer case. By the way, have you installed the driver for the device? Hope this can help you.
Kind regards
Andrea
Window shut down
Sounds like a hardware issues. It may be having problems switching from the main power connection to battery.
Top HEWLETT-PACKARD Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a HEWLETT-PACKARD Tablet and eReader Expert? Answer questions, earn points and help others
