SOURCE: Tub seal has rip therefore washer is leaking.
Its pretty comlicated requires dissasembly of the front of the washer. A good tech can do in 1 hour. You may want to pay for it rather than spending all day and possibly damaging something. Let me know if you need further assistance.
SOURCE: Ordering CCU for kenmore elite 45986
Are you attempting to replace the Main Computer Microprocessor, or the User Interface? The Main Computer is located inside the washer behind the wash tub, while the User Interface is behind the control panel. The term CCU sometimes gets used interchangeably and I need to be sure.
It's easier to order parts directly from searspartsdirect.com. Just type in your model number (located around the door opening) and you will find both of the parts I mentioned under the "Control Panel" heading. If you wish to try a local Sears dealer in your area, you can use the part numbers provided by the Sears website.
I hope this helps you. Please post back if you need further assistance.
PS If you wish to compare pricing, you can also try repairclinic.com. Both sites get their parts from the same part source. They both offer comparible pricing with one or the other often having better deals.
SOURCE: How Do I replace the
Here ya go, click on the following link for step-by-step instructions:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Read through the instructions thoroughly before starting. This is a fairly straight forward and simple repair job. If you require further assistance, go to my profile and use the "Ask Me" feature for a quicker response. I hope this helps you.
SOURCE: I have a Fridgdare front load washer FWT449GFS2.I
boy, you must really love that washer! as far as i've been able to determine, and i've done a lot of research on this, the seal is only available in the assembly. don't know why they'd design it that way, but it's been a source of frustration to a lot of techs
SOURCE: how do i get my washer to stop leaving grease
if your getting grease it is the vbearing
but it may need a transmisiion as well
