SOURCE: Scag SMT61A Mower with Kawasaki 27KA engine. 200
try taking stater fluid to carb and try keeping it running,needle seat might have some dirt in it or the carb itself needs to be cleaned.
SOURCE: I have a 14 HP Kawasaki engine on my John Deere
All the "safety" engine-kill "features" on this mower will ground the ignition system, stopping the engine and causing a no-spark condition. Check the seat switch, the brake switch. Also, the circuit board will cause the problem you have if it gets rained on, (the mower hood does not protect it); point is do not let the mower get rained on (or washed) unless you protect the PC board, which is right behind the ignition switch. Mine dried out and worked again but only after liberal spraying with (plastic-safe) electronic parts cleaner. You are right the manual would help, it's like $76 but it's in depth. Good luck, and PLEASE tell us what the solution was!
-Tom
Helpful Deere lx176, lx178, hood hinge tip: If the hood hinge is broken on yours like on most, Deere has a GREAT repair kit that's only $10. They really priced it at cost or less to correct a defect they are aware of.
SOURCE: No spark wont start
i have a 2007 kawasaki brute force 650 4x4i... my problem is , i recently change and reset the beltlight... now the bike starts run for a bout 1 minute and stop. What might the problem be?
