I have found that Tally 7.1 rel2.1 is compatible with Windows XP, Windows 7 as well as Windows 8. Try installing this version of Tally and I am sure it will work.
Is windows 7.2 64 bit compatible with Tally 7.2?
Activate windows click here: www.acyberkey.com
you can find the keys you want in a low price that you have never imagined.
SOURCE: how to run turbo c++ in windows 7 64-bit os
Is the program not installing at all? Or it just won't run?
Try using the compatibility options for it. If the program did in act install, open up the start menu, and right click on the application. Select properties. There is a compatibility tab. On that tab you can select the Checkbox to run the program in compatibility mode - WindowsXP SP2 usually works for most legacy apps.
SOURCE: i am not able to run turbo c++ on my windows 7.it
Depending on your version of Win7 and your computer specs, you could try to run the software in the XP mode (Pro or Ultimate). This is a virtual machine and needs dedicated memory and does not directly share files or peripherals with the real machine. It has worked well on our machines for several older programs (Win2K and XP versions) - these were 32 bit programs and ran on a 64 bit Win7 Pro machine.
Running the program in the compatibility mode might work as well (right click, choose properties and then the compatibility tab).
I hope this helps.
SOURCE: I'm trying to upgrade from 64-bit Vista to 64 bit
Regarding the concern, please make sure that you are trying to install 64 bit of Windows 7 and not 32 bit of Windows 7.
It is not possible to install 64 bit Windows 7 on a 32 bit Windows Vista and same goes for 32 bit Windows 7 on 64 bit Vista.
Let me know if you need any further help.
SOURCE: HOW TO RUN TURBO C IN 64 BIT WINDOWS 7
Turbo C/C++
64 Bit operating systems like Windows Xp64, Windows Vista64, and Window
7 will no longer run 16 bit applications and this includes Turbo C
2.01/Turbo C++ 3.0/3.1 or the programs they produce.
Turbo C 2.0 was first released in 1989, Turbo C++ 3.1 in 1991 making
these programs nearly two decades old. They are just too old to run on
modern PCs.
Upgrade To Modern Compiler
Note that Turbo C/C++ is very very very very old and produces 16 bit
programs which no long run on many modern computers. So the best advice
is to upgrade to a new compiler. There are many free compilers out there that you can use.
Free Compilers:
If you are just working with C there is:
All of the above are Free and all excellent replacements for Turbo C which is so old it will not even run on your computer.
Regards.
