Amana ASD 2624 Side by Side Refrigerator Logo
Posted on Aug 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My amana fridge is not keeping cold but the frezzer is working fine i am very good at fixing things my self i just need to no what the problem is the fridge is about 4 years old purchased from home depot
Anonymous
Level 2:
President:
  • Expert 3,773 Answers
  • Posted on Aug 08, 2011
Anonymous
Expert
Level 2:
President:
Answers
3773
Questions
Helped
609143
Points
163
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned warmer which makes REF. colder or vice versa.
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Amana refridgerater freezer will not keep freezer frozen
this might have something to do with the defrost disk located in the frezzer behind the panel, its a small round disk attached to your coils. get a part or model number and look it up. hope this helps.
I have a model MTB1956GE Maytag Fridge, Frezzer
Can you feel air moving or hear the fan running in the freezer section? You said the freezer section is freezing well, but is it freezing really hard?
Regards,Richard
7helpful
2answers
My Kenmore refrigerator is not cooling properly. Freezer portion works fine but not refrigerator. Came on suddenly.
I had the same problem. The frezzer worked but the fridge was not getting cold. What I have learned is that the frezzer make the fridge cold, so if the frezzer is working then something is blocking the cold air to get into the fridge. Most likely ice. The air come in at the bottom of the inside of the fridge next to the frezzer. Pull everything out of the frezzer, then unscrew the plannel that runs along the back and you see if there is ice. If so turn frezzer off and dry out the frezzer. I used hot water.
My kenmore fridge mod# 59662822200 will not keep cold
you need to test the defrosting element in most cases this is the problem either that (most common or the defrost timer (least common or the frezzer fan ( secound least common in most cases its the defrost element it does not defrost the air flow tubes leading to the fridge compartment thus the cold air cant get through
good luck
Fridge and freezer not getting cold
If it was layed down to move and not let sit for a while before using it again it would not work. Somtimes leaving in off and let it settle will straighten it out but not all time. The oil in the compressor get into the cooling lines and blockes the freon. Other than that, check the condenser coil which are near the compressor. They should be warm when the compressor is runnin. If they are not warm there is a compressor or freon problem.
Amana BR18 Doesn't get cold
Mine is doing the same thing
1helpful
Freezer works fine refrig part not keeping things cold
It may be that your timer is stuck and the defroster doesent know when to come on.I will bet you have ice obstructing the flow of coid air to the Goodies department. the frezzer works but that;s a diffrent compartment. I fixed a lot of thease, I hope I can fix yours. #1 take everything out and put in ice chests. #2 look on the back of the fridge. Find a hole that a screw driver will fit in to a switch. This switch is known to stich up, ok . Turn it several times in a clock ward direction , end up where you started.hopefuly this will unstick the sensor ,timer . But let it totaly melt out you have ice build up in the upper half. once all is melted out , turn on the unit, you should be cold in the Goodies Department. hope this works for you. DFD please rate me TKU
2answers
FREEZER WORKS BUT FRIDGE IS 50-55 DRGREES
if all that is ok then you need to check the heater and bi-metal / if it starts frosting up you loose air into the refrig side and the freezer will start going down too / frig side gets tem from freezer ,,,,, i bet you have a bad defrost heater / larry
The refrigerator is not keeping tempurature. Freezer is working fine
Either the freezer fan has stopped blowing air or the defrost timer has stopped and the airways to the fridge are clogged with ice. Only the freezer gets cold in a refrigerator. The fridge part gets cold by cold air being blown through air passages from the freezer. Good Luck!!
barneyluc
Every thing in the frezzer/fridge is warm
what is the model number of the fridge
Top Amana Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
