SOURCE: The compressor only reach 50 PSI.
Does the compressor continue to run but not build more pressure? In which case it is an air leak most likely, or does the compressor shut off at 50 PSI? In which case it is mose likely the pressure switch. If it is an air leak you can un-screw the guage and coat with putty or teflon tape and reinstall to clog the leak around the threads..
