Question about Husqvarna Hand Held Blower 125 B Grass Leaf Blower ()
MY ELECTRIC LEAF BLOWER RUNS BUT NO AIR IS COMING OUT
  • 252 Answers
Hi there ssh4990
pauly46 here
is the blower fan turning ? or has the connection between fan and motor shaft been broken / shawn ?
is the air intake blocked ?
has the fan blades been broken off ?
is the outlet tube blocked ?
check these out as thats about all it could be
have a look and let me know
cheers
Posted on Aug 06, 2011
Testimonial: "Thanks for your help. After attempting to lubricate the shaft.The shaft still wouldn't rotate freely. All your check suggestions seemed to be ok."
Anonymous
SOURCE:
Brushes on the motor are bad. where can I buy them
Sounds like the brushes are worn out and in need of replacement, if available.
Nov 04, 2011 | RTO Weed Eater Electric Barracuda 2595...
Electric dryer runs, drum turns, gets warm, cleaned out vent, but still not getting clothes dry.
The most common problem for a dryer to take more than one cycle to dry is restricted air flow.
1.when the dryer is running go outside and find where the venting is located, there should be a good amount of air flow.
2. if the air flow is not good look at the ducting coming from the back of the dryer and make sure it is not kinked or pushed back to far.
there is usually lint build up some where along the ducting or at the end of the duct where it vents to the outside.
3. if you have access to a leaf blower,this can be used to help clear any lint build up inside the duct from the dryer to the outside venting.
move your dryer out and take the leaf blower tube and stick it in the hole and turn it on.
the vented louvers need to be removed from the ouside of the house to allow the lint and things in the duct work to be blown out.
Feb 13, 2011 | Maytag Dryers
Black & decker blower/vac runs slow, problem started all at onceruns slow
I've had the same problem at work with troybuilt leafblowers. It eventually turns off as you use it yeah? It could be a little flooded and the engine isn't getting enought air. Find out where the carbeurator is, take it off, dump out the excess fuel, and spray out with WD-40 or carb and choke cleaner, make sure there's not a lot of excess fluid left and then try it. I've seen and old guy try it on a lawnmover I had that kept doing the same thing, and it fixed it just like "that".
Jul 17, 2010 | Black & Decker Leaf Hog 12-AMP Electric...
My dryer is not getting hot its not drying clothes even when they have been in for 3 hours
Is dryer getting warm at all. If it is your heater and t-stats are fine. Make sure it is exhausting to uotside properly. Turn dryer on and go to outside exhaust. you should leel air coming thru pretty good. If low air flow pull dryer from wall, disconnect hose at wall and using leaf blower blow the exhaust out to the outside. Impotant thing to remember is blow from behind dryer at the wall to the ouside. Not outside in. Also, electric works better than gas blower due to exhaust fumes caused by gas leaf blowers.
Jan 27, 2010 | Hoover Dryers
Kenmore series 90 electric dryer: exhaust air is
that's normal,obviously you haven't cleaned out your dryer and vent line,nobody ever tells the customer when you buy your dryer that it should be cleaned out at least once a year so you don't have a fire more so if it's a gas dryer with an open flame inside the dryer,you gotta vac out the inside where the motor is,clean out the duct that the lint filter slides into and blow out the vent line,i use a leaf blower to clean out the vent line,take it off the back of the dryer,stick the leaf blower in the line if it's a long run if it runs through the wall and to the outside flapper and blow all the **** out of it,also if you have a shop vac put it on blow and blow off the motor,you won't believe how much lint comes off the motor even though it looks clean,so vac out the inside of dryer,clean out the lint filter duct and blow out the vent line
Dec 18, 2009 | Kenmore Dryers
Leaf blower runs then sputters and smoke poors out of exhust then runs and repeats cycle like it is burning oil.
Sounds like its not getting enough air, check the air breather filter. Stephen.
Oct 07, 2009 | Garden
Blower stall after few seconds
sounds like you not getting enough gas,or you are getting air in gas line,, check for air bubbles in gas line,, if you dont have any then clean the carb. good,, hope this help you
Aug 29, 2009 | Homelite 'Yard Broom' Leaf Blower
Homelite back pack leaf blower
Close both the high and low speed air screws (clockwise). Reopen each 1 1/2 turns
Mar 20, 2009 | Homelite 'Yard Broom' Leaf Blower
Husqvarna Hand Held Blower 125 B Grass Leaf Blower () Logo
88 people viewed this question
Top Husqvarna Garden Experts
Marvin
Marvin
dannydoesita
Wayne McNeil
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
