Tip & How-To about Car Audio & Video
Dei viper python valet hornet boa transmitter programming help
DEI REMOTE PROGRAMMING INSTRUCTIONS
Need a DEI Remote Replacement Now? Try our all New Remote Quick-Find
Not sure what type of Replacement Remote you need?
In order to enter Learn Routine, the Valet/Program push button must be plugged
into the main brain's Blue 2 Pin Port (Look for a small black push button located under
the drivers dash or drivers kick panel somewhere). If you do not have the Valet/Program switch, you may order it at www.lesscoelectronics.com or www.lesscosales.com
1)
Open a door and make sure the dome light is on.
2)
Turn the ignition on to the RUN position or you may also start car.
3)
Within 15 seconds press and release the Valet/Program push button
to select the channel you wish to program. For example, press and release
once for channel 1 (arm/disarm channel).
For Channel 2, press and release twice (trunk release).
For Channel 3, press and release three times (remote start).
(Some DEI systems require different programming for different channels. You
can get specific installation manuals with remote programming instruction)
Press and hold the Valet/Program push button once more. You should get a
confirmation chirp/horn-honk or a flashing LED light (If installed).
If you do not get a chirp/horn-honk the alarm may have a jumper in
the alarm that has the programming feature turned OFF (disabled).
4)
Once the alarm chirps/horn-honks keep holding the Valet/Program push button.
5)
Press the button on the transmitter that you would like to control the selected receiver
channel. A chirp/horn-honk will confirm that the code has been learned. If programming
more than one transmitter repeat step 5. Old transmitter codes will be dropped only
if programming 4 new transmitters.
6)
Once the code(s) are learned, the Valet/Program push button can be released.
Learn Routine will be Exited if:
Ignition is turned off
Door is closed
Valet/Program push button is pressed too many times
More than 15 seconds elapses between steps
One long chirp/horn-honk indicates that Learn Routine has been exited.
Car Audio & Video Logo
remote starter instructions
First, locate your valet/programming switch. Once you have located the switch, turn the ignition on, press and release said switch then press and hold. Now, while holding the switch, press the lock button on the remote. the vehicle/alarm should respond with a chirp/horn honk. Release the valet switch, turn the ignition off, test the system.
Jul 25, 2012 | Vehicle Parts & Accessories
programming instructions for remote RC24912-E5818
If do not have the instructions Google the model number for "manual" to try to locate them.
Jun 15, 2012 | General Electric RC24912-E Universal...
I have a Sharp TV and cant find my remote control. I have a Jumbo remote control that I would like to program but don't have the codes and instructions on how to program it. Can you help me?
Yes, I can help you...and I'm sorry you had to wait so long for an answer. You will need to go to the website that is the name on the jumbo remote. Example: www.jumbobrandname.com . If you are having trouble locating a web site for this particular remote, you can go to www.universalremote.com for a complete list of "codes" and "programming instructions". But try to get to the web site that coordinates with your remote first. When you get to your chosen site, you will either click onto "codes" or type "codes" in the search box. Make sure you jot these codes down as you will need to try different ones. You will see several codes for every brand of televisions. After you've jotted these down, next you need to go to "programming instructions". Print this page out as you will need it in front of you while you are programming your remote. Follow the easy, step-by-step instructions and I'm confident you'll be operating with your jumbo in no time! Enjoy your day!
Jan 28, 2011 | Innovage Jumbo Remote Control
Hooked up a Viper 5301 in a 2004 Nissan Murano. The problem I'm facing is that the unit is only programming when the vehicle is started and running, instead of programming after turning the ignition on then off, like the instructions say to do. I've been installing car audio/video/alarm systems for 12 years and never had this happen with a DEI system. What could this be?
It sounds like you have your ignition and starter wires reversed. The remote start programs when the ignition wire sees 12 volts and then loses the 12 volts. If you have the remote starts igniton wire on the trucks starter wire then that is why you can prgram it when you start it only... cause you get 12 volt only when the truck cranks and then loses the 12 volts once it is runnng. You may have the right colors from the remote starter correct but check to see if maybe from DEI they have the wires in the wrong positions.
Jan 20, 2011 | 5301 Responder LE 2Way Remote Start and...
Had to change the battery in my Python Keyless Start/Remote and now it wont work. How do I reprogram it
To program remote:
turn ignition on
press and release programming switch once ( the siren/horn will honk once)
press and hold programming switch
while holding programming switch, press lock button on remote ( the unit will chirp/honk to confirm programming)
turn ignition off
test remote
Oct 07, 2010 | DEI Python 1400XP Remote Start/Keyless...
781 people viewed this tip
Top Car Audio & Video Experts
Marvin
Marvin
Mark Skinner
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
