Tip & How-To about Computers & Internet
Faulty Laptop LCD screen
FAULTY LAPTOP LCD DISPLAY
You may have a faulty inverter or defective CCFL lamp. A faulty CCFL lamp may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering and/or with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight or a faulty inverter that supplies high voltage to the CCFL lamp. Usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.lcdparts.net
Computers & Internet Logo
my compuetr screen does light up when power is connected it dark
www.ladparts.net
Dec 14, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
power supply to the screen backlight keeps going out
www.ladparts.net
Dec 14, 2009 | Dell Inspiron 1525 Notebook
turned my gateway mx3414 laptop off, when I turned it back on the screen was black, turned off and restarted several times always just a black screen.
www.ladparts.net
Dec 13, 2009 | Gateway Computers & Internet
screen is black
If the notebook appears to boot up and the LED hard disk light flashes then :-
www.ladparts.net
Dec 13, 2009 | Acer Aspire 5100 Notebook
I have a toshiba Satellite a135-s2386. It powers on but nothing on the display. I think I need a new motherboard. But am not for sure. What is the part number for this motherboard. any help will be appreciated
Does the laptop appear to boot up but the screen id blank?
Does the hard disk LED light flash?
If so you may have a faulty inverter or defective CCFL lamp. A faulty CCFL lamp may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering and/or with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
www.ladparts.net
Dec 09, 2009 | Toshiba Satellite A135-S2386 Notebook
36,791 people viewed this tip
Ekse
Marvin
Marvin
