Tip & How-To about Toys
Troubleshooting and Fixing Model Trains That Won't Run
If your train won't run at all, the first challenge is to find what is wrong. If the problem only started after you made recent changes to the track or trains, start there first. If you have no idea where to begin, the six steps below will walk you through the most typical problem areas.
Some problems are easy to solve. If you have a broken locomotive or power supply,
Your engine gets its power through the wheels. Make sure all of the locomotives' wheels are on the track by sliding it back and forth gently. Try moving the engine to a different part of the track to rule out a loose rail joint or electrical connection.
Start with the connection between the wires and the track, then the connections between the wires and the power supply . Make sure nothing is loose and the wires don't touch. Make sure the wires are connected to the terminals for the track and not accessories. Inspect the wires themselves to make sure they are not frayed or split. Check the electrical plug and socket, too. Is the outlet turned on?
If you're setting up for the first time, you can probably skip this step entirely. Dirty track and wheels usually result in rough stop-and-go running, not a complete loss in power. If you've had the trains put away for a long time, especially in a damp environment, you could have corrosion or dirt build-up heavy enough to prevent operation altogether.
If you do notice heavy dirt or corrosion, it can usually be removed with some special abrasive cleaning blocks and liquid cleaners
It's important to be sure that the power supply is working. The surest way is to use an ammeter to read the electric current. If you don't have an ammeter, a simple test tool can be made with a low voltage light bulb and two short pieces of wire.
If you don't detect any current at the supply outputs, disconnect the wires to the track and test again. If you get a light, then you probably have a short in the track or wires. If not, then the problem may be a faulty power supply.
If everything checked out at the power supply, retrace the wires to the track again and test here. The ammeter will work, or if you have a second locomotive or even a lighted passenger car or caboose, try putting it on the track.
If you are getting good results with this test, the problem is probably in the locomotive itself. If you are just starting out, your best option is to return the locomotive or find a local service location
If you have detected a short circuit in the track, check your wires again. A short circuit can occur any time one rail or wire touches the opposite rail or wire. If you have more than one set of power leads, make sure they aren't crossed. It is a good idea to color code your wires.
If you are using the 2-rail track, make sure you haven't created a short in a reversing loop or wye . Switches and crossings can also cause a short if the opposite rails touch without an insulated break
Don Derail Troubleshooting Model Train Problems
Toys Logo
My 1985 Skyhawk won't start. Cranks well but no start
BAD COIL OR IGNITION MODULE INSIDE DISTRIBUTOR RUN OHM TESTS TO VERIFY
perego Choo Choo will make noise, but won't move
the sounds are run off of a different battery source, check the battery under the seat and make sure that its connected
1999 chevy k2500. changed spark plugs 4 times in 7 months. Runs good for a week then doesn't start. Changed spider, throttle body sensor. Still has no codes and once again won't start.
The next time it won't start ,pull a sparkplug wire and see if you're getting fire.Then we'll known whether its a ignition or fuel problem and go from there.
How does the e3200treadmill fat calories work with the regular calories burnt.
Add incline. Instead of keeping the treadmill on a flat surface, maintain an incline as you walk, jog or run. This will serve to replicate the wind resistance and terrain variation that you encounter when you run outdoors. Keep an incline of at least 1.5 percent on your treadmill throughout your workout.
  • 2 Increase your speed. If you run at the same speed every time you workout, your body will not be challenged and you may reach a fitness plateau. Up your speed by a quarter-mile per hour every few weeks.
  • 3 Vary your workout time. In order to challenge your body in different ways, variety is key. If you run for half an hour three times a week, opt for a one-hour run for your fourth workout. This will help to condition your body for endurance training, resulting in more calories burned.
  • 4 Use intervals. Interval training can dramatically increase your calorie burn in an average workout. Instead of running at a steady pace for your entire workout, mix in sprints. Jog at a steady pace for two minutes, and then increase your speed to a full sprint for 30 seconds. Return to the steady pace to recover. Your heart rate will rise on your intense sprint intervals and stabilize on your longer recovery periods.
  • 5 Incorporate incline into your interval training. You can use incline in the same manner that you would speed to interval train. Walk or jog at a 5 percent incline for two minutes. Increase the incline to 10 percent for two minutes and then to the 15 percent maximum for one minute. Decrease the incline back to 10 percent for two minutes and finally back to 5 percent for two minutes. Repeat this same pyramid interval a few times.
  • 6 Wear a heart rate monitor. This will monitor how hard you are actually working as well as how many calories you burn in each workout. You can then adjust your speed and incline accordingly to maximize your calorie burn.
  • 7 Drink plenty of water before, during and after your treadmill workout. If you are dehydrated, you won't perform as well as you can. You'll work harder and burn more calories if you're hydrated
  • Not finding what you are looking for?
    Top Toys Experts
    ADMIN Andrew
    ADMIN Andrew
    john h
    Are you a Toy Expert? Answer questions, earn points and help others
