Tip & How-To about Canon Office Equipment & Supplies
Example: How to change your mp3 player background
brother printers, like all printers, need regular maintenance to operate properly. Some maintenance depends on how often the machine is used, how many pages are printed on a regular basis, etc. If you notice your Brother printer is having trouble getting paper out of the paper feeder, the problem is likely due to either a dirty pickup roller, separation roller, or both. These rollers will become dirty over time from paper dust and other airborne debris.
The ink absorber box or flushing box is nearly full. These components are periodic maintenance items that may require replacement after a period of time to ensure optimum performance from your Brother machine. Because these components are periodic maintenance items, the replacement is not covered under the warranty. The need to replace these items and the time period before replacement is dependent on the number of purges and flushes required to clean the ink system. These boxes acquire amounts of ink during the different purging and flushing operations. The number of times a machine purges and flushes for cleaning varies depending on different situations. For example, frequently powering the machine on and off will cause numerous cleaning cycles since the machine automatically cleans upon power up. The use of non-Brother ink may cause frequent cleanings because non-Brother ink could cause poor print quality which is resolved by cleaning. The more cleaning the machine requires the faster these boxes will fill up.Solution Replace ink box replacement Or you can try to vacuum the toner out of the ink box Ink box is container to the far right . gl edward austin associates
The ink absorber box or flushing box is nearly full. These components are periodic maintenance items that may require replacement after a period of time to ensure optimum performance from your Brother machine. Because these components are periodic maintenance items, the replacement is not covered under the warranty. The need to replace these items and the time period before replacement is dependent on the number of purges and flushes required to clean the ink system. These boxes acquire amounts of ink during the different purging and flushing operations. The number of times a machine purges and flushes for cleaning varies depending on different situations. For example, frequently powering the machine on and off will cause numerous cleaning cycles since the machine automatically cleans upon power up. The use of non-Brother ink may cause frequent cleanings because non-Brother ink could cause poor print quality which is resolved by cleaning. The more cleaning the machine requires the faster these boxes will fill up. http://support.brother.com/g/b/faqlist.aspx?c=as_ot&lang=en&prod=dcpj4110dw_eu_as&tabid=2
The ink absorber box or flushing box is full. These components are periodic maintenance items that may require replacement after a period of time to ensure optimum performance from your Brother machine. Because these components are periodic maintenance items, the replacement is not covered under the warranty. The need to replace these items and the time period before replacement is dependent on the number of purges and flushes required to clean the ink system. These boxes acquire amounts of ink during the different purging and flushing operations. The number of times a machine purges and flushes for cleaning varies depending on different situations. For example, frequently powering the machine on and off will cause numerous cleaning cycles since the machine automatically cleans upon power up. The use of non-Brother ink may cause frequent cleanings because non-Brother ink could cause poor print quality which is resolved by cleaning. The more cleaning the machine requires the faster these boxes will fill up.
Other reasons for cleaning are:
The machine automatically cleans after clearing a printer jam.
The machine automatically cleans itself after sitting idle for more than 45 days (infrequent use).
The machine automatically cleans itself after the ink cartridges have been replaced 12 times.
If your question was not answered, please check...
The ink absorber box or flushing box is full. These components are periodic maintenance items that may require replacement after a period of time to ensure optimum performance from your Brother machine. The need to replace these items and the time period before replacement is dependent on the number of purges and flushes required to clean the ink system. These boxes acquire amounts of ink during the different purging and flushing operations. The number of times a machine purges and flushes for cleaning varies depending on different situations. For example, frequently powering the machine on and off will cause numerous cleaning cycles since the machine automatically cleans upon power up. The use of non-Brother ink may cause frequent cleanings because non-Brother ink could cause poor print quality which is resolved by cleaning. The more cleaning the machine requires the faster these boxes will fill up.
The ink absorber box or flushing box will need to be replaced.
Machine automatically cleans after clearing a printer jam.
Machine automatically cleans after sitting idle for more than 45 days (infrequent use).
To ensure consistent print quality and prevent
damage to the print head, your Brother machine will perform maintenance
purges of the print head at regular intervals. These purges remove any
air or debris that may have gotten into the print head manifold. Your
machine will use the minimum amount of ink necessary to perform this
operation.
