The steering handle has a red switch on it. Pull the switch to the right and then twist the handle grip forward. The stroller should start to collapse.
Infant seats sit rear facing. You'll have to recline the stroller seat. Then the clip on the infant seat will grab the food tray and lock it in. Your stroller might have come with an additional strap to secure the seat once you have it locked.
unfortunately I believe you have to buy a new chassis jus for the handle bar. The best way is to just buy a handle bar cover for the handle bar. That will cover the damage and also protect it from further damage.
i have both the double and single dreamer design stroller and on both - there is a black pull thingie ... if you put your hands on the handbar and then follow down the frame (along the back side of the seat). You will feel it - as it is kinda hard to see. Once you pull this on both sides, push down on the handbar - towards the ground. The stroller will then fold down and in half.
I find that the best way to do this is the following;
Make sure that nobody is standing behind the pram (expecially small people!)
Make sure that the seat unit is raised.
Stand to one side of the pram, bend down and with both small black plastic buttons, push inwards (so that they are going toward eachother)
The back of the pram should fall to the floor.
Where the childs back of the knees are, lift up the fabric a little and grab the black metal bar, then lift this up and the pram should collapse nicely. You should have a ******** the handle bar with a popper on to secure this shut.
Standing behind the stroller when you look down towards the basket, look along the frame, just above the rear "step" on the right side you will see a plastic lever that usually has the number one on it, step on it. On the other side you will see an identical lever that usually has a number 2 on it, step on it, while holding it down with your foot, pull up slightly on the handle bar then push down and back to you at the same time. The stroller will fold and you lock it in place by taking the oblong shaped rings attached to the handle bar and hooking them over the "pegs" on the side of the stroller near the bumper bar.
