20 Most Recent
Bruder MAN TGA Container Service Truck Questions & Answers
I have MAN TGA 18.350 it seems on dash board CHECK TCO wht does it stands for
The "CHECK TCO" message that appears on the dashboard of a MAN TGA 18.350 truck is likely related to the truck's TCO (Transport Control Outlet) system. The TCO system is responsible for monitoring and controlling various aspects of the truck's operation, such as the exhaust gas temperature, the engine oil pressure, and the coolant temperature. The "CHECK TCO" message is likely indicating that there is an issue with one or more of these systems and it needs to be checked by a qualified technician. You should refer to the truck's manual for more information on the TCO system and how to troubleshoot the issue.
ZBR failuer
Hello Muhammad. May I know where r u from ? Im from Malaysia. You can try to replace a new ZBR. I think it cost below RM1000 and send it back to MAN Truck & Bus for settings the ZBR.
What is edc code 0094
Hi
I am no expert on this but I think it may be low fuel pressure as mentioned by others and that replacing fuel filter may fix this issue.
Blocked or dirty filter can cause low fuel pressure. Maybe even air in fuel line can cause this and bleeding fuel line (diesel) may help.
Cheers
What is the trouble code EDC 03779-10 on man diesel truck and how can I solve it
3779-10 and 3778-10 could point towards possible injector failure. Try changing your filters, cleaning out the fuel lines etc but you'll more than likely need to get a leak-off test carried out to diagnose which (if any) injectors are at fault and go from there.Copied fromhttp://www.trucknetuk.com/phpBB/viewtopic.php?t=71351
Ffr 00647-10
Problem with Bruder MAN TGA Container Service TruckFFR 00647-10
