Wont start have a traxxas revo 3.3
Hello!! ,
To the point!!! , All gas cars are "Nitro" , there are "Gas" Cars but there more expensive and fairly new... , by my experience Ez starters dont have wires on them in order to start the motor.. , if you cut!! a wire.. in there maybe it could be it... , but these cars dont need ground wire.... ,Sooo if u say its ground wire i dont think theres a problem , its only incase if there's an electrical over-out-charge that will put the chips in danger... , so THIS MESSAGE IS QUITE COMPLICATED : ) ... ,
and it shouldn't turn over there not designed that way , only if you put another motor that maybe is'nt apropriate that has more speed or power if i may or it does'nt have a back "Wheel" Slider..., and if the gears got something in it well... , maybe they might chiped a "Tooth" there and is not gearing well wich may lead to more gear problems as u can imagine , check the steering batteries too , or maybe it just needs "Idle-ing" so the motor can run Fine and Dandy like Tom Hanks says jaja , but i think the problem is that your not Idle-ing it well in twisting the Knob fairly 1/8 at a time to get a smooth sense and sound of the motor because it can over heat , or maybe there's something about the carburator that's not working well , Orrrr maybe it needs a clean with white Gas in unscrewing all the "Motors" Parts and cleaning them for a while so the motor can run better , Ive got an Exceed Rc "Mad Storm" so im kinda of guessing but they all work quite almost the same , Hope this helps : ) Ciao!!!!!
