20 Most Recent
Peg Perego John Deere Farm Tractor and Trailer Questions & Answers
JD 1630 turns over but won't start
John Deere 3179DL-01 diesel 3-cylinder liquid-cooled 179 ci [2.9 L] What is the Temp. in degrees outside. if below 35 degrees it will be a problem. Some tractors are cold natured and a diesel needs plenty of cranking amps to start. Have you tried either ? If you do try either, crank the engine before you squirt it into the breather, and only a small amount. Either is hard on engines this is why you use it sparingly.
Farm pro raider(Homier)
Only thing left is compression. Stuck valves will affect compression as well as worn rings.
JD push mower doesn't have enough power to throw
I would have a compression check done on the push mower,if it has bad compression the engine needs rebuilt or replaced. As far as the bent bracket,if you can straiten it thats what I would do,mabey get a torch an heat it first.
