20 Most Recent
Shuttle 9094 Emax Remote Control Helicopter Questions & Answers
My bottom propellers won't turn. What could be the
Same happened to me. I've found out that the white gear at the end of the right motor, that conects to the wheel and makes the blades spin, has been worn out by the harder plastic of the wheel itslef. So now they are no more in contact and thus the lower blades wont sping. I temporarily solved it pulling the white gear a bit lower but it lasted only for a couple flights more :-(
My silver bullet helicopter wont take off, the top blade is spinning but the bottom one isnt
Kindly check the rotor carefuly.. there is one white/black color rotor fixed on the bar of Motor rotates whith motor and there is anoter rotator which attached parally with its i.e once motor rotator moves the another ones also moves (which connected with the rod of Blades) some times these rotators gets loose by time and makes the rotation of Blades weak. kindly connect the same tightly and check....
The brookstone stunt copter and remote donot sync
It would not sync. solution was to assume poor technical writing.
step zero. turn the controller off.
step one. plug in the battery to the copter.
step two. QUICKLY turn the controller on. if you miss this small window of time, it is going to fail. The copter light blinks fast during this period, and if it slows the blink rate, then you have waited too long.
I have Brookstones silver bullet
Sometimes the metal weights fall out of the top rotating bar causing the blades to be out of balance and the bottom blade to hit the tail. Check to see if both the weights are in the top bar.
